Brake Light Switch
Discussion in 'Technical Chat' started by Troyton, Jun 9, 2019.
  1. Jun 9, 2019 at 4:10 PM
    Troyton
    Troyton [OP] Well-Known Member
    Troy
    South Florida (Naples)
    06 DoubleCab PreRunner "Wanna be XSP"
    -Trd shocks -Clifford Alarm System -Kenwood Radio -Led bars -Green Fog Lights -2010 Head lights and Tail lights -2010 Tail gate with Back up Camera -White Dash Mod -2011 grill -Led Pods -Kicker Subs -PA System - Underglow
    Recently I have had brake light issues and the truck wasn’t coming out of park so I changed my brake light switch and changed the 10A Stop fuse for extra measures. But the new switch keeps my brake lights on continuously and when I press the button down it turns them off? I opened up the switch and it seems to work as should. Now when I plug either the new or old one in the brake lights don’t turn off and I can press the button to turn them off. What am I missing here? Thanks in advance
  2. Jun 9, 2019 at 4:14 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Sounds like a relay issue.
    Troyton[OP] likes this.
  3. Jun 9, 2019 at 4:23 PM
    Troyton
    Troy
    Now which relay would that be
  4. Jun 9, 2019 at 5:46 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Check your owners manual. It’ll tell you.
  5. Jun 10, 2019 at 1:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Sounds like a adjustment issue .
    When the pedal is in the normal position the arm of the brake pedal should keep the switch pushed in that is the open position of the switch when the pedal is pushed in this allows the switch to close lighting the lights.
    I am not a AT person but if the ECM does not detect the brake light signal it will not come out of park I know there is a bypass if the brake light circuit fails
    Unless they added a Relay in the newer trucks there should not be one
  6. Jun 11, 2019 at 1:13 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Plug the switch in, lights are on right?
    Now depress the plunger on the switch, are the lights still on?
    If not, then install the switch and adjust it until the lights are off.
    Then push the pedal, lights should come on
    Release the pedal and ensure the lights go out
    If not adjust the switch till they do.
    Simple system, now, have you made absolutely sure there is only one switch?
    Some vehicles have 2........
    Maybe some pics would help us help you.
  7. Jun 11, 2019 at 1:18 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The brake light switch may be bad.
  8. Jun 11, 2019 at 1:20 PM
    Gixerkiller
    Dennis
    Taylor, TX
    Doubtful that two switches would be bad.......but maybe....
  9. Jun 11, 2019 at 1:28 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    From the original post it sounds like the switch is fine but for whatever reason the brake pedal is not pushing on the switch plunger. How brake switches work is when the pedal is at rest the plunger is pushed in breaking the circuit thus brake lighrs are off, then when you push the pedal you are letting the switch plunger extend(spring inside) thus making the electrical circuit whole and turing on the brake lights. To check this remove the switch and with it plugged in push the plunger in, lights should be off. now let the plunger extend, lights should be on. If that works correctly then look at where the brake pedal makes contact with the switch plunger, plunger should be pushed in all the way when brakes are not applied.
    I hope this is not to confusing, it's a really simple system that people get confused about since when the button is pressed the switch is off, which goes against what one expects
  10. Jun 11, 2019 at 2:23 PM
    Lester Lugnut
    You're probably right. I was suspicious the switch came from Auto Zone.
  11. Jun 11, 2019 at 3:11 PM
    Gixerkiller
    Dennis
    Taylor, TX
    Oh, vato zone....never mind it very well could be bad...
  12. Jun 12, 2019 at 1:20 PM
    Troyton
    Troy
    Thanks so much. My fault from beginning. I thought it was a simple “press the button for break lights” kinda switch but I guess not.
  13. Jun 12, 2019 at 1:24 PM
    Troyton
    Troy
    Was from Rock auto which I don’t know if it’s any better. They sent me a third anyway so I have a spare
  14. Jun 12, 2019 at 1:30 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    At least you got it sorted out
