Brake lights don't work can't shift out of park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabassman, Oct 7, 2017.
  1. Oct 7, 2017 at 2:47 PM
    Gabassman
    Gabassman [OP] Drive it like a 4WD
    Tyler
    Georgia
    Hey everyone. It's been quite sometime since I've been on here. I've got a bit of a problem. My brake lights do not work nor do the brake lights on my trailer. I have to push the break bypass button every time to get the truck out of park. Out side of looking at the fuses I have no idea what to look for to resolve this issue.
  2. Oct 7, 2017 at 2:48 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Does this happen with the trailer unplugged?
  3. Oct 7, 2017 at 2:51 PM
    ModestMods
    ModestMods Well-Known Member
    Jax, Fl.
    2012 DCLB 4x4
    Suspension. Billy 5100's all four corners. Fronts set at 0 with Eibach 620 coils for level. Tp14 spacer driver side. Wheels. 17" ultra mavericks with 265/70/17 nitto terra grappler g2. Exterior. super white grill. Debaged. Black housing headlights. Black Led third brake light. Black Depo Tail lights Interior. Led interior bulbs. Neoprene seat covers
    it sounds like you have a short somewhere. Have you recently changed any break Bob's or done anything to your wiring?
  4. Oct 7, 2017 at 2:51 PM
    ModestMods
    Jax, Fl.
    2012 DCLB 4x4
    Bwahahaha talk to text is horrible...
    *brake bulbs
    beeip likes this.
  5. Oct 7, 2017 at 3:00 PM
    Gabassman
    Tyler
    Georgia
    Yes with trailer unplugged aswell with the 7-5 adapter removed. No bulbs or wiring changes recently.
  6. Oct 7, 2017 at 3:04 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Your brake switch probably went bad. Short across it and see if it works then
  7. Oct 7, 2017 at 3:14 PM
    Gabassman
    Tyler
    Georgia
    We're is this brake switch?
    Also I can hear a click in the steering column when trying to shift out of P
  8. Oct 7, 2017 at 3:18 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    It's behind the brake pedal
  9. Oct 7, 2017 at 3:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is either the brake switch, brake fuse or the shift lock solenoid. Switch is on the brake pedal under the dash.
    ModestMods likes this.
  10. Oct 7, 2017 at 3:26 PM
    Gabassman
    Tyler
    Georgia
    Ok I'll give it a shot. Thanks for some direction.
  11. Oct 7, 2017 at 3:46 PM
    Gabassman
    Tyler
    Georgia
    Thanks for the help. Ended up being a fuse. Ended up being the one labeled stop. I passed right over it yesterday when chasing down my problem
  12. Oct 7, 2017 at 4:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    With that fuse blown you had no voltage to the brake switch and no power to the shift lock solenoid.
    Good job. :thumbsup:
  13. Oct 26, 2017 at 5:13 AM
    Gabassman
    Tyler
    Georgia
    Well the fuse blew. I threw a larger 15 amp fuse in just to get Home with brake lights. The 15 will last a couple of weeks before blowing. I’m in the field working and the abs light came on and the fuse blew. I had been trying to find the time to investigate further but but I’ve been way too busy. I had planned to look into the aftermarket trailer wire plug I had to splice in but now I’m not sure since the abs light has came on. The brake switch maybe shorting out? Going bad?
  14. Oct 26, 2017 at 9:46 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The ABS light can come on because of a brake pedal switch / stop fuse fault, as it is an input signal to the ABS module.
    Most likely you have a short to ground elsewhere - your trailer connection, a rubbed wire, a shorted brake light bulb even (rare, but it can happen), stop switch, or even the shift lock solenoid itself, listed in the order of probability.
    Jimmyh likes this.
  15. Jul 10, 2018 at 7:07 PM
    Gabassman
    Tyler
    Georgia
    So i figured it out. The brake wires in my camper shell got shorted out. Thanks everyonne
