Brake lights not wotking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chalo5, Apr 16, 2016.
  1. Apr 16, 2016 at 3:51 AM
    Chalo5
    Chalo5 [OP] New Member
    2009 Tacoma DB Cab
    Hey everyone l'm new to this forum and need some help I have a 2009 Tacoma access cab it has the LED tail lights and my brake lights don't turn on including the third light I have checked the fuses under the dash and under the hood and they're good went to ask at a auto store and was told i had to buy the hole tail lights is that true or is there something im missing? Thanks in advance
  2. Apr 16, 2016 at 4:27 AM
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    There's a switch that your brake pedal engages that send a signal to the brake lights to turn on when you stop. If the tail lights come on with your headlights, that might be the problem. I had the brake lights not work on an old Nissan Sentra that my wife use to have. That ended up being the problem. I don't think it was too expensive to fix.
  3. Apr 16, 2016 at 11:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the brake switch on the pedal assembly. A good way to test the brake switch is to set the cruise control and then press the brake, if the cruise control kicks off the switch is working.
    Also check the fuses with a multimeter, they may appear good visually and still be defective.
    shakerhood likes this.
  4. Apr 17, 2016 at 8:29 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    ^^ What they said.
