brake lights on constant when Truck is running
Discussion in '1st Gen. Tacomas (1995-2004)' started by browntd2609, Jul 22, 2025 at 5:54 PM.
  1. Jul 22, 2025 at 5:54 PM
    browntd2609
    browntd2609 [OP] New Member
    So the brake lights (all three) are on when the ignition is in the run position, no pressure on pedal, they stay on as if pedal was depressed, when you turn the ignition off the lights go out, press the pedal with ignition off brake lights come on as they should be. Any ideas how the lights are getting power through the ignition? Is this a defective brake light switch?
