brake lights out
Discussion in 'Lighting' started by legend3433, Apr 9, 2013.
  1. Apr 9, 2013 at 8:24 AM
    legend3433
    legend3433 [OP] Member
    Tacoma, Wa
    07 V6 SR5 4wd
    3 in lift (23.25 front/24.50 back) 285/75R16 tires on factory wheels
    So about 6 months ago my brake light just stopped working. The reverse lights & blinker lights still work. Its not the light bulb because I've changed them and nothing happened. About 5-6 years ago I had a stereo installed, that's the only cause I can think of.
    Just wondering if anyone had any ideas and what I might be able to do to fix them......hopefully I can do it myself, if not it seems like it would be an expensive fix. Any advise would help...thanks.
  2. Apr 9, 2013 at 1:45 PM
    mdep03
    mdep03 Well-Known Member
    New Jersey
    03 reg cab 4x4 2.7L
    K&N intake, 3" sus lift (front- billstien 5100 w/ toytec coils, 2" rear toytec shackles and aal's), 32x11.50 15 Pro Comp MT, 15x8 Pro Comp soft8 flatblk, 4x innovations rear tube bumper & Rock sliders, low range off road front bumper, Hella 7" fogs behind the grill, custom floor mats and rain guards, corbeau seats, HiLift Jack, and clear side markers. and a bit more
    I don't know but I have the same problem but it's only the reverse lights that don't light up when in reverse. Do you have a trailer harness or wiring for a cap? Maybe a loose ground? Thats what I tried so far
  3. Apr 10, 2013 at 8:55 AM
    legend3433
    Tacoma, Wa
    07 V6 SR5 4wd
    I do have a trailer harness. I don't believe I have wiring for a cap. The trailer harness was already on the truck when I bought it new in 07. Where do you check for a loose ground?
  4. Apr 10, 2013 at 9:01 AM
    TacoCat
    TacoCat Look away, I'm hideous!
    Johnny-5
    Chantilly, VA
    Silver 2010 OR
    have you checked the fuse?
  5. Apr 10, 2013 at 9:48 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Remove the tail light, make sure light socket is clean, have a buddy press brakes, test socket with multimeter. No power? then follow wires from that brake light making sure they are not damaged. No damage? check and see if the trailer harness is hooked up to them. If it is, check connection. If it's not soldered, take it apart, solder it, shrink wrap and electrical tape. If on the wires there is green/white corrosion, cut affected areas out and solder. Hope this helps.
  6. Apr 30, 2013 at 9:14 PM
    boal12
    boal12 New Member
    Devine, TX
    4dr PreRunner SR5
    2.5" lift
    Have you checked your brake light switch? It's located under your brake pedal. Unplug the small wiring harness that goes into it. It a blue plug with four wires that is plugged into a white switch. After removing the blue wiring harness give the white switch half a turn and pull down. That is your break switch you can either replace it or take it apart and clean the contacts as I did.
