Brake lights stay on
Discussion in 'Lighting' started by LocoTaco, Jan 2, 2015.
  1. Jan 2, 2015 at 7:49 PM
    LocoTaco
    LocoTaco [OP] Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    Just this evening I noticed my brake lights are staying on, is there a switch or something along that line that could need replacing?
  2. Jan 2, 2015 at 8:17 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    On my 2014, there's a pin switch at the top of the brake pedal.
  3. Jan 2, 2015 at 9:02 PM
    LocoTaco
    Don
    Central Washington
    09 SR5 TRD Sport
    Thank you, I will look for it and replace it.
  4. Jan 2, 2015 at 9:04 PM
    cgs2k2
    cgs2k2 old man
    i had the problem of my brake pedal sticking like a centimeter down from being fully disengaged, which kept the brake lights on. try to lift up on it a bit and see if that is the case with you as well. i ended up spraying a bunch of lubricant on the spring for the pedal return and it helped
