Brake Lights?? Wtf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Jul 31, 2019.
  1. Jul 31, 2019 at 12:33 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    hey all,
    I have a weird issue. I changed all the bulbs on both sides of my rear brake and turning lights. My left upper brake light is out even though I changed the bulb. On the right side, all the lights are working but they are dim. They are shining at about half the luminosity of the lights that ARE working on the left side. The right side blinker is hyperlinking but ONLY when I apply the brakes. When I release the brake pedal, the right side blinker resumes normal blinking speed. All bulbs were changed. Seems like an electrical issue but where do I start? Thanks!
  2. Jul 31, 2019 at 12:47 PM
    Muddinfun
    Muddinfun Well-Known Member
    The 1st thought is, why did you change all the bulbs?
  3. Jul 31, 2019 at 12:47 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    How much voltage you getting at the socket?
  4. Jul 31, 2019 at 12:52 PM
    2009Access4x4
    Shane
    I don’t. How can I check that?
  5. Jul 31, 2019 at 12:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What kind of bulb did you replace them with? A picture of the package would help
  6. Jul 31, 2019 at 12:54 PM
    tcjacado
    tcjacado Well-Known Member
    Volt meter.
    wilcam47, blu92in99 and Gunshot-6A like this.
  7. Jul 31, 2019 at 1:19 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Your '09 doesn't have the LED tail/brake lamps, with regular bulbs for the turn signals and reverse lamps?
    ...and upper brake lamp bulb? I recall there being only 3 bulbs in the taillamp housing; upper (turn signal), middle (tail/brake), lower (reverse).
    Show us a pic of what each side (left/right) is doing.
  8. Jul 31, 2019 at 1:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you replace them with LED Lights?
    tcjacado, DGXR and Too Stroked like this.
  9. Jul 31, 2019 at 2:57 PM
    2009Access4x4
    Shane
    I forgot to mention: the right blinker goes fast but ONLY when my foot is on the brakes
  10. Jul 31, 2019 at 3:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There is certainly some fuckery amuck.
    wilcam47 likes this.
  11. Jul 31, 2019 at 4:06 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  12. Aug 2, 2019 at 1:35 PM
    2009Access4x4
    Shane
    Update: I talked with a shop. They are going to look for broken wires and/or a ground wire that is failing. Any other suggestions are appreciated!
  13. Aug 2, 2019 at 1:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds like bad ground somewhere...the fun part is finding it...
    Jimmyh likes this.
  14. Aug 2, 2019 at 9:48 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    First thing I'd do is put the bulbs you had back in and see what happens.
    If it does the same scenario then look for a ground problem or something loose.
    Find that then start building back, change your bulbs to what you have now and see what happens.
    My girlfriends old car was a 95 Nissan Altima. I noticed one night when she was leaving that the taillights became all messed up when she pressed the brakes.
    I checked voltages at the plugs, checked resistance from the ground terminal to a bolt, all were great but the problem persisted.
    I finally started digging into the taillights themselves and found a screw terminal with ring lugs on one of the lights that both lights fed through. It was loose and along with some other loose connections caused her problem.
    After tightening up everything they worked correctly. I guess the moral of the story is to also check the housing and pay attention to the connections.
    Tullie D likes this.
  15. Aug 3, 2019 at 6:06 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Agreed.
    Worked on an S10 that had a screwed up ground for the lights on the rear of the frame. I don't recall exactly what it did... but it was something like that, I think the tag lights were flashing with the signals too. Even weirder, if you hooked up a trailer it worked way more normally... turned out because it didn't have a converter box or anything for the trailer lights and that harness had its own ground, so with the trailer connected the truck lights were then getting a good ground as well.
