[solved] Brake line flare nuts stuck; cut hard line out, replaced with new
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 7, 2015.
  1. Dec 7, 2015 at 10:22 AM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I solved my problem with fresh new vice grips and cutting out the hard line. Details are on pages 5,6,7 of this thread.
  2. Dec 7, 2015 at 10:23 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I had the same issue with my 3rd gen 4runner..
    what i did:
    grabbed a large set of blue handle channel locks.
    gripped it nice and tight.
    twist.
    voila
  3. Dec 7, 2015 at 10:24 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    This is why I've been sitting on my SS brake lines for a year or two now...
    greeneggsnspam likes this.
  4. Dec 7, 2015 at 10:24 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks...I tried the channel locks too, but when I try to break loose, the hard lines begin to rotate with the nut, and the brake lines will move from their seat on the bracket...
    whoareyou133 likes this.
  5. Dec 7, 2015 at 10:25 AM
    ramonortiz55
    Ramon
    Texas
    stock
    on a side note, the channel locks were new. so the teeth were at their sharpest.
    whoareyou133 and Crom[OP] like this.
  6. Dec 7, 2015 at 10:28 AM
    ramonortiz55
    Ramon
    Texas
    stock
    ouchhhh
  7. Dec 7, 2015 at 10:30 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Mine have been sitting since April. lol
    I am thinking of using a propane torch to heat the nut. Maybe 5-7 seconds of direct flame...
  8. Dec 7, 2015 at 10:55 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I would say get a buddy to hold the brake line firm at the base of the nut and use some big sharp toothed channel locks. But also u have to get that stupid thing back on but hopefully never again. and only 11ftlbs which is a lie. Penetrating oil the shit out of it for a few days.
    Manwithoutaplan and Crom[OP] like this.
  9. Dec 7, 2015 at 11:00 AM
    Crom
    Nick
    San Diego, CA
    Millions
    I did break one loose on the axle bracket, the other mangled nut should come free with sufficient force and maybe heat. Even if that hard line is trashed, it's not too bad to replace, since it's a short piece from the drum to the bracket.
    I am most worried about the nuts on the frame bracket. Such a shitty location, and those hard lines I want to be real careful with. So f'ing painful. Want to burn the truck down. lol
    I had two different shop mechanics crawl under truck and look at it and they're like... yup... pain in the ass... We'll try...
    scottalot likes this.
  10. Dec 7, 2015 at 11:02 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    ya mine was a few splint knuckles and a smashed thumb for the top two on the back. Having a second set of hands was worth it, my buddy tapped the 10mm box wrench with a mallet while i held it tight to the nut.
    scottalot and Crom[OP] like this.
  11. Dec 7, 2015 at 1:09 PM
    Crom
    Nick
    San Diego, CA
    Millions
    After lunch bump.
    Anybody torched the nuts to get 'em to break loose?
  12. Dec 7, 2015 at 1:14 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    i think only downside is the brake fluid in there but u will be flushing it also. I have used heat a few times on nuts and it worked well.
  13. Dec 7, 2015 at 1:15 PM
    ramonortiz55
    Ramon
    Texas
    stock
    id be too scare that thing would catch on fire with the oil inside them lines..
  14. Dec 7, 2015 at 1:18 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I wouldn't use too much heat, maybe a hand held bic lighter, but def. not a torch.
    When I did mine I think I used a nice big pair of vice grips and got them VERY tight. If needed I've used a second set of pliers to help lock the vice grips closed. Then slowly twist away.
  15. Dec 7, 2015 at 1:25 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    Yes you need vice grips.
    chadstacoma and Crom[OP] like this.
  16. Dec 7, 2015 at 2:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you are going to use heat in that location I would suggest a heat gun vice and open flame.
    Also you want to heat the FEMALE part not the male nut. that way the threaded hole will expand and get looser. If you heat the male tube nut it will get tighter.
  17. Dec 7, 2015 at 2:42 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Jimmy,
    Thanks for chiming in. Yes. I did try a heat gun on the female side (soft brake line crimped fitting), but I don't think it got hot enough.
    I realize it's hazardous with the open flame. I've got a welding pencil tip torch, so I can focus the flame well...
    If I shield the rubber brake line with foil and hit the brake line fitting with a blue flame for 5-7 seconds, It may help, that's what I'm thinking. I could also try again and go back to the heat gun and try that some more, but I felt it took too long to heat up, and then everything was hot.
    Thanks. I need to get some better ones than what I got now. but strong locking vise grips seem to be the ticket.
  18. Dec 7, 2015 at 2:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yeah it is a bitch in tight spaces... I wish you luck and not too many skinned knuckles!
    I'm sure you will get it.
    Crom[OP] likes this.
  19. Dec 7, 2015 at 2:47 PM
    Pigpen
    Dan
    Northwest Montana
    I wouldn't worry about a propane flame, it's not like you're using acetylene
    ecoterragaia and Crom[OP] like this.
  20. Dec 7, 2015 at 2:57 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Beyond the above mentioned methods you could also try a little pipe wrench since it will tighten down and grab, just be careful you're not rounding it off even more.
