brake lines
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_dee151, Aug 16, 2025.
  1. Aug 16, 2025 at 8:39 AM
    TRD_dee151
    TRD_dee151 [OP] Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    who all gots a 2.5 inch lift and still using factory brake lines?
  2. Aug 16, 2025 at 11:51 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    You talking about the rubber hoses going to front brake calipers, and the brake hoses on rear diff, not the “hardlines?”
  3. Aug 16, 2025 at 12:43 PM
    TRD_dee151
    Oregon
    brake lines in the rear
  4. Aug 16, 2025 at 12:56 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I do. I made a spacer for under the junction bracket on the axle, raised that up about an inch. At full droop, I have nice, loose hoses.
  5. Aug 16, 2025 at 6:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You don’t need longer brake lines if you have OEM replacement shocks. All you are doing is changing the resting point in the range of motion of your suspension, not the min or max (not more than about 1”).
    CAVEAT: top hat spacers in the front do change the suspension geometry, but AFAIK do not require longer brake lines. Drop bracket lifts are also a different sort of animal.
    It you want to know for sure, jack your truck up by the frame until the tires leave the ground and check the tension on your brake lines.
  6. Aug 16, 2025 at 6:17 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Stock brake lines here since early 2020. Zero issues.
    TRD_dee151[OP] likes this.
  7. Aug 17, 2025 at 9:17 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Extended my mine because of dobinsons extended travel rear
  8. Aug 17, 2025 at 9:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I did this too, just put some washers or a spacer under the hardline bracket on the axle tube and use a longer bolt (8x1.25).
    It'll give more slack than you think
    You shouldn't really need brake lines until you go over 3 inches and/or get extended travel shocks
    OldSchlPunk[QUOTED] likes this.
