Brake Master cylinder 2008 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gettinridofher, Jul 15, 2017.
  1. Jul 15, 2017 at 3:08 PM
    Gettinridofher
    Gettinridofher [OP] New Member
    Hey guys and gals!
    Started having spongy brakes. I can still brake and at times they vary in their sponginess.
    Bled all brake lines at the wheel twice, replaced the front brake pads(just to trouble shoot they looked fine), back pads were fine. Have not had any drop in my brake fluid so I am 99%sure there is no leak also noted there is no fluid under the truck ever.
    All that being said, I'm going to attempt to replace my master cylinder as my research tells me that is the culprit. It is pretty accessible and my friend is encouraging me to try it myself. Any warnings, encouragements, tips would be appreciated!
    2008 4x4 TRD v6 4L
  2. Jul 15, 2017 at 7:09 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    When you bled your brakes did you do a full fluid flush, or did you just bled them? Brake fluid is hydroscopic and will absorb moisture out of the air. This will change the performance of the brake fluid and the feel of the pedal. If you didn't do a full fluid flush, I would try that before spending the money on a new master cylinder.
  3. Jul 15, 2017 at 7:35 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  4. Jul 15, 2017 at 8:58 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Your gonna need a scanner to bleed the abs module. Make sure your rears are adjusted properly and no leaky wheel cylinders. Bench bleed the master before install. It helps to have a buddy help you once you bench bleed it to do the Indiana jones switcharoo. The less time you leave the lines disconnected from the master the less air you will introduce into the system.
  5. Jul 15, 2017 at 9:02 PM
    Bishop84
    Bishop84 Well-Known Member
    Make sure also to adjust the vacuum booster to compensate for the new master or it will feel softer, or worse, drag.
    It is critical to adjust the booster properly.
  6. Jul 16, 2017 at 7:29 AM
    Gettinridofher
    Hey thanks for all the replys. Would you guys recommend I just pay to have it flushed properly before attempting any big moves? I literally just ran about 1L of brake fluid through the system. No thing gritty came out, no sputtering(obvious air). That's all the videos online showed. But perhaps I should have it done by a professional.
  7. Jul 16, 2017 at 7:37 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Are your rear drums adjusted properly? You will have long pedal travel if they aren't
  8. Jul 16, 2017 at 8:15 AM
    Gettinridofher
    I haven't had any of them adjusted ever. But the brake pedal varies in it's response. It certainly is not consistent with its response. For instance I've noticed if I pump them they get better most of the time.
