brake modulator? bleeding brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by normbal, Apr 5, 2010.
  1. Apr 5, 2010 at 7:48 AM
    normbal
    normbal [OP] Well-Known Member
    Norm
    socialist occupied Maryland
    White SR5 long bed
    minor mods. Hood moustache, truckchamp SS oval step-bars, Go Rhino Hitch step, popnlock plus tailgate hoseclamp, Weathertech digitalfit floor mats. Wheel and spare tire locks.
    okay, Ive bought the SS brake lines, and ordered a set of hawk pads, in the interest of trying to take some of the mushiness out of the system (2010 4x4 V6 tacoma).
    I came across a post online referring to special electronic tools needed to bleed some brakes, Tundras specifically:
    "The modulator can contain 8 - 10 Anti-lock or traction control valves, aswell as other dead end ports and check valves. Some cars have special bleed screws built into the system which make this whole process a lot easier, allowing the air out of all the trapped areas. Others do not have bleed screws and needs a scan tool, which can cycle through the valve system whilst you bleed the mechanism, allowing all of the air to escape"
    Damn. Is this going to complicate things?
    Thanks.
    Norm
  2. Apr 5, 2010 at 7:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    No-two people a couplwe bottles of flUid and time-No sweat
  3. Apr 5, 2010 at 8:03 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think OP is asking about bleeding ABS system
    To OP...
    Just bleed the brakes, then find road with loose ground and steep incline.
    1. Drive forward (down the hill) press brakes until ABS kicks in. Turn around
    2. Drive backwards (down the hill) press brakes until ABS kicks in.
    Bleed your brakes again.
    That should clear out your ABS unit.
    EDIT: I do that on all my cars I just don't feel like spending all that money on Toyota tool. That process works on any ABS system.
  4. Apr 6, 2010 at 8:04 AM
    normbal
    Norm
    White SR5 long bed
    Now to find a hill I can do this on without Maryland's Finest busting me. :(
