Brake module for towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nature, May 23, 2024.
  1. May 23, 2024 at 11:17 AM
    nature
    nature [OP] New Member
    Doug
    Boulder, CO
    06 PreRunner
    Add tow hitch
    The trailer has brakes but the 2006 Tacoma is not TRD. Just 2WD. From what I understand I don't have anywhere to plug a brake module into to run it to the 7 pin (blue).
    https://www.amazon.com/Reese-Towpow...l/dp/B000CQSKV8?ie=UTF8&qid=1315974379&sr=8-1
    What are my DIY options to be able to add the trailer brakes? Or am I just missing something?
    I also know I'm missing other things the tow package includes like oil/tranny cooler. Been towing w/o for years but this trailer is a bit bigger than past ones so considering the tranny cooler.
    203K miles on my Taco. Had it since 54K. Runs like a Tacoma.
  2. May 23, 2024 at 11:26 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does your truck have a 7-pin connector in the back?
    Or are you saying the trailer is 7-pin and the truck has no connector?
    Not even a 4 pin?
  3. May 23, 2024 at 11:33 AM
    nature
    Doug
    Boulder, CO
    06 PreRunner
    Add tow hitch
    Originally it did not even have 4-pin. There's no tow package. Everything has been added by me. I put on the Class 3 hitch and wired in for 4/5 pin (trailer/camper). When I got this trailer I bought the 7pin for the truck (trailer has it) and just wired on the green/yellow/brown/white. And then I rigged up a bad idea for red ;).
    TnShooter[QUOTED] likes this.
  4. May 23, 2024 at 11:54 AM
    TnShooter
    Deogee
    STOCK
    You'll have to wire in a brake controller. (Like the one linked)
    You'll need to tap in to a brake light wire (in cab) then run the wire from the controller to the 7-pin.
  5. May 23, 2024 at 12:38 PM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    Everything you should need to add the tow package equivalent parts is in this thread. It even covers the wiring you are going to need to do with part numbers, though my truck came with the factory tow package so I haven't personally validated this
    The Tacoma Towing Bible | Tacoma World
    deanosaurus likes this.
