Brake motor whining?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Oct 22, 2014.
  1. Oct 22, 2014 at 12:55 PM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    I have an 09 and when I step on the brake I can hear what sound like a little motor or whining sound running. The sound seems to be coming from the left side of the steering wheel underneath the dash.
    If i hold my foot the brake and slightly release and push down on the brake, the brake will go lower to the floor.
    Thanks!!!
  2. Oct 22, 2014 at 7:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What is a Brake Motor? You may be hearing the Vacuum Brake Booster...
  3. Oct 22, 2014 at 7:56 PM
    smd3
    smd3 Well-Known Member
    The TRDOR has a pump that pressurizes an accumulator, I only hear mine when I turn the key to on, just before starting the truck.
    How often do you hear the pump?
  4. Oct 22, 2014 at 9:16 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Zactly. If your brake pump runs all the time that means you have air in the system. Bleed the brakes if you are smart, if you are not take it to a good mechanic or the dealership and get it unfucked.
  5. Oct 23, 2014 at 5:02 AM
    smd3
    It could also be a bad accumulator, or something allowing pressure to release.
  6. Oct 23, 2014 at 7:04 AM
    boxxed
    Denver, CO
    09 Off Road
    I didn't know how else to describe it..
  7. Oct 23, 2014 at 7:05 AM
    boxxed
    Denver, CO
    09 Off Road
    I hear it every time I step on the break.. It has been getting worse.
  8. Oct 23, 2014 at 7:17 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You have a master cylinder going bad you need to deal with that pretty sharpish.
  9. Oct 23, 2014 at 2:38 PM
    boxxed
    Denver, CO
    09 Off Road
    I made an appointment for the dealer.. Maybe Ill get to use the warranty I bough!!!:eek:
  10. Dec 2, 2014 at 11:33 AM
    boxxed
    Denver, CO
    09 Off Road
    So to follow up with my brake sound issue. Apparently is is normal.
    On a side note, The tech said it sounded like I had ha wheel bearing going out and also I tech that I replaced some of the coolant in the overflow 2 times druing 81000 miles thats on it.
    Thank god I have the extended warranty is all I can say..
    One thing though I had to go back and get my keys out of my truck and I saw the air was let out of of both front tire so the guy could work on it eaiser. So now my truck is sitting on the wheels. Do you think that will do any damage.
    Dave
  11. Dec 2, 2014 at 12:35 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Not unless it's driven that way around the lot, or it sits there for long period of time.
