Brake noise at first take off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sam81, Mar 21, 2009.
  1. Mar 21, 2009 at 12:38 PM
    sam81
    sam81 [OP] New Member
    Southern IL
    08 PreRunner Off Road
    Hi everyone. I have an 08 double cab PreRunner that makes a noise when I first take off from a start. I have noticed it seems to be coming from the brakes because if I hold my foot on the brake peddle it will not make the noise until I release it. It only does this when the truck has been shut off, even if its only been 10 minutes or so. I am only moving ay 3-6mph when it happens. It kinda sounds like pressure being released. A quick, not very loud noise. I called the dealer and they've not yet gotten back to me and I have searched the forum for similar issues. Anyone experiencing this or know what it may be? Thank you for any help. Sam
  2. Mar 21, 2009 at 12:54 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Sounds like the ABS, it normally only does it after it's been shut off over night or so. Mine does it every morning when I pull it out of the garage. It's probably normal, I'm not sure it should do it every time you restart your truck though.
  3. Mar 21, 2009 at 1:02 PM
    fletch aka
    Gary
    Left Coast
    I found this on another post on this same issue.
    "The noise you are hearing is the ABS system doing it's system check, this will happen every time you stop the engine, let it stand for about 15min or more and then start out again. There is nothing wrong with your truck, they all do it and yes Toyota INC. is still working on a fix for this."
    Hope this helps.
  4. Mar 21, 2009 at 1:04 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Mine does this also but its only when i go in reverse if the truck has been shut off alittle while. It only does it for a few seconds, i usually can pump the brakes as im backing up and it stops within a few seconds.
  5. Mar 21, 2009 at 5:11 PM
    sam81
    Southern IL
    Thank you all. You would think the service manager at the dealership would have known this but who knows? Thanks again. I'm sure we'll talk more later.
