Brake Noise???????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAXTacoma, Dec 4, 2009.
  1. Dec 4, 2009 at 3:15 PM
    MAXTacoma
    MAXTacoma [OP] Well-Known Member
    Lexus GS 350
    Ok I have about 58k on my truck and have never changed the brakes. I tow alot especially in the summer. I took my truck about 6 months ago (approx 50k) to get the brakes check and they said it had over 50% of the brake pades left. My truck had made a noise in the front end when I hit the brakes. This is the complicated part. The noise only comes when I hit the brakes the first time after driving in reverse and hitting the brakes then driving forward and hitting the brakes. It never makes the noise after the first time of hitting the brakes in forwards or reverse. Does that make sense? I have put the truck in 4x4 and it still makes the noise. It doesn't make any noise turning or any other time. I have look under the front end and dont see anything unusual. The only thing I noticed was that it seems that my brake pads on the drivers side are loose inside the brake caliper. So evertime i hit the brakes it moves one way or the other. Has anyone else experienced this. Am I crazy? When has everyone else changed there front and rear brakes?
  2. Dec 4, 2009 at 3:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I know my brakes squeak every once in a while and I only have about 29,300 miles on my truck. It has been doing it for a while now. Chris4x4 said its normal though so I dont sweat it.:cool:
  3. Dec 4, 2009 at 3:31 PM
    garzanium
    garzanium Well-Known Member
    Texas
    05 Taco 4x4 dsm 6in. procomp,moto rims, 33bfg
    Ya,im at 82k miles and occasionally my breaks squeek when I lightly engage and first start driving in the day. Then it goes away.
  4. Dec 4, 2009 at 3:35 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Clunking sound rather than a squeal I would guess? Sounds to me like a retaining clip or spring is loose, missing or broken. That may be allowing your pads to move forward and backward in the caliper. They really shouldn't move around in the caliper.
  5. Dec 4, 2009 at 3:38 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    If your talking about a "rattle," it's normal. Mine does this too. It's just the pads shifting in the direction the rotor is spinning when the brakes are applied. Nothing to worry too much about. :)
  6. Dec 4, 2009 at 4:52 PM
    MAXTacoma
    Lexus GS 350
    I think that it has to be a loose brake pad bc it makes more of a clanking noise than a squeak. How could my pad be loose inside the calipers?
  7. Jan 2, 2010 at 9:19 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    did you fix this? my truck is doing this. forward/reverse...a clacking sound. i will wait for daylight, and check it out. i suspect a clip is gone or broken. fun..i have 3 days before a roadtrip. i will probably just change out my 50% pads.
  8. Jan 3, 2010 at 12:16 PM
    aficianado
    back to bone stock.
    to close this thread..
    my old pads shifted every so slightly. so the pad change looked simple enough. (exactly the same procedure as my 1981 porsche 911SC!!). pads definitely at 50%. no harm tossing in some new stuff. quick pad change, and VIOLA! the noise is gone. (for now). pedal tautness also improve immensely.
  9. Jan 3, 2010 at 12:21 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    Mines a stick, so i changed them at 101,000
  10. Jan 3, 2010 at 12:56 PM
    MAXTacoma
    Lexus GS 350
    No I never changed them. I think that I'm going to try and take a look at the pads in the next few weeks... I guess I'm just used to it since they hae been doing this for about 9 months.
