Brake oil flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zarragoicoechea, Sep 25, 2024.
  1. Sep 25, 2024 at 1:37 PM
    Zarragoicoechea
    Zarragoicoechea [OP] New Member
    Paul
    Tacoma 2015
    I have 157,000 miles on my 2015 Tacoma V6…
    Ive never flushed the brake fluid, i do my own oil changes and brake pads and drums, spark plugs and serpintine belt, I replaced the transmission oil, the radiator fluid and steering fluid. So far, my Tacoma runs excellent!
    Ive had zero probs with my brake fluid and reservoir is topped off.
    Seems kinda like an upsale?
    Has anyone had probs from not flushing their brake fluid?
    I want to get at least a few hundred thousand miles out of the engine and more if possible.
    HondaGM likes this.
  2. Sep 25, 2024 at 1:43 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Don't know what the manual reccomends but I've flushed brake fluid every 2 or so years since ownership. It's quick, easy and reassurance there isn't moisture in the fluid.
  3. Sep 25, 2024 at 1:44 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I replace my brake fluid every 4 years. Brake fluid is hydroscopic and absorbs water.
    O'DubhGhaill, drizzoh and HondaGM like this.
  4. Sep 25, 2024 at 1:45 PM
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    I honestly blead mine only because i had to put new calipers on mine. I upgraded to dot 4 and noticed some improvement after. What happens is brake fluid overtime absorbs moisture. So, your truck being a 2015 like mine and never had it done, I would personally. Just have a 2nd guy their to help you. Thankfully these trucks are easy to work with on that and do not require scan tools like the gmt900 and up gm trucks. Rule of thumb is change fluid every 2-3 years since it absorbs moisture. I personally noticed improvement. But thats my experience. Just figured id share with you since you asked.
    HondaGM likes this.
  5. Sep 25, 2024 at 1:58 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    In the long term, leaving contaminated brake fluid in the system will corrode metal components in the system. Anyone who has ever worked on old unmaintained cars or bikes will remember the cloudy gray/blue/green stuff that comes out of brake lines.
    joeyv141 and HondaGM like this.
  6. Sep 25, 2024 at 2:04 PM
    Zarragoicoechea
    Paul
    Tacoma 2015
    All good advice above, I will flush it to be safe. thanks
    HondaGM likes this.
  7. Sep 25, 2024 at 2:11 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I think it is a no-brainer. It is cheaper and easier than all the other things you have done (other than needing a 2nd person to bleed it the old fashion way). I have 2012 with 87k and I just flushed mine for the first time last year and I thought it braked better afterwards (less spongey).
    Zarragoicoechea[OP] and HondaGM like this.
  8. Sep 25, 2024 at 2:20 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW....
  9. Sep 25, 2024 at 2:40 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    I’m going to get some of the speed bleeders mentioned in this thread: https://www.tacomaworld.com/threads/brake-and-clutch-fluid-maintenance.837294/page-2#post-30146819
    The link goes to the last post where the part numbers are for those. But read the whole thread.
    Very easy job to DIY, but you must absolutely ensure the fluid level does not drop to empty and suck air into the system.
    Watch a YouTube on it. Search for Tacoma break bleeding, although the process is about the same for most vehicles.
    O'DubhGhaill likes this.
  10. Sep 25, 2024 at 2:42 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I use the motive power bleeder, worked great and it’s a one person job. I also change out my bleeders when I do it just to be safe, front bleeder valve: 47547-04010, rear bleeder value: 47547-12040.
    HandOfGod and O'DubhGhaill like this.
  11. Sep 25, 2024 at 4:48 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Flush mine every 60k.
  12. Sep 25, 2024 at 11:05 PM
    Zarragoicoechea
    Paul
    Tacoma 2015
    Thanks for everyone’s input. Im gonna do it.
    I appreciate all the Tacoma enthusiasts!!!
    Tacoma’s are reliable and well built trucks! I am a contractor and use it for carrying heavy loads = Tools, rack and ladders and supplies etc. Its my mini shop on wheels.
    I Just changed my oil approx 4 hrs ago.
    Changing all fluids regularly will or should make them run for 300,000 - 500,000 and maybe more. The engines are built well.
  13. Sep 25, 2024 at 11:11 PM
    Zarragoicoechea
    Paul
    Tacoma 2015
  14. Sep 26, 2024 at 8:54 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Hi Everyone - hoping everyone is well.
    I'm in the same camp as others - change mine and frequently. I live on the westcoast B.C and we do get a lot of rain / moisture. I would suggest picking up a brake fluid tester first and to measure the moisture of the brake fluid. If it is more that 3% then change it out / flush the fluid. It's just that easy....always a good to have a couple of cold ones while working on the Tacoma.
    Best to you all - go team TW !
    spitdog and Knudsen like this.
  15. Sep 26, 2024 at 9:11 AM
    TJTM
    TJTM Active Member
    2009 2.7 l, 4x4 access cab
    I change mine every two years or so. I've been told (possibly an opinion rather than fact) that it helps prevent sticking calipers along with the other benefits.
    ( no moisture in the lines)
  16. Sep 26, 2024 at 9:14 AM
    IL Capo
    Sidney BC Canada
    your absolutely correct....I take the opportunity if I'm flushing the brakes to also service the brakes. Why not....I'm already up to my elbows into it now.....
    How do you put a price on peace of mind?
  17. Sep 26, 2024 at 9:15 AM
    Knudsen
    Jon
    Same price as a 6 pack :rofl:
  18. Sep 27, 2024 at 1:32 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I don't flush mine either, but what I’ve always done when I do a brake job is replace the brake fluid in the reservoir with fresh fluid. It’s a multi step process - remove brake fluid before starting brake job; push in the caliper pistons to remove fluid that is pushed into the reservoir; fill reservoir with new fluid; install pads; top off reservoir after pumping the brakes. I will do a flush only if I open the system.
  19. Sep 27, 2024 at 1:58 PM
    TacoTuesday1
    FL
    Have I had problems from not flushing
    no because I do it like you’re supposed to. Not hard. Some manufacturers call for every 1 or 2 years.
    just did my friends truck on the floor.
