Brake Overide Malfunction Won’t Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SgtPuddin, Jan 7, 2019.
  1. Jan 7, 2019 at 9:27 AM
    SgtPuddin
    SgtPuddin [OP] Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    driving truck and brake overide malfunction pops up on dash. Truck continues to drive fine. Park truck turn off. Now truck won’t start. All the lights work but truck does nothing when brake pedal is pressed and start button pushed.
    Any ideas.
    2018 off-road tech and premium auto
  2. Jan 7, 2019 at 9:30 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Check brake pedal electrical connections for any loose wires would be my first response (after yelling WTF)
    2016trdtacoma likes this.
  3. Jan 7, 2019 at 9:31 AM
    ChronicTaco
    ChronicTaco Well-Known Member
    British Columbia
    Canadian Special
    Disconnect the battery for a bit and see if that helps.
  4. Jan 7, 2019 at 9:31 AM
    SgtPuddin
    Mississippi
    Did the battery thing. Disconnected negative for 5 min.
  5. Jan 7, 2019 at 9:32 AM
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    2018 truck? Sounds like a warranty issue to me...
    shakerhood likes this.
  6. Jan 7, 2019 at 9:32 AM
    SgtPuddin
    Mississippi
    Tow truck is coming. Problem is I’m in a parking garage fourth floor.
  7. Jan 7, 2019 at 9:34 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Are your actual brake lights working when you hit the pedal?
    I had my brake light fuse blow (box under the hood but I forget which fuse exactly) which caused this to happen - brake lights didn't work -> system malfunction -> no start.
  8. Jan 7, 2019 at 9:34 AM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    Find a push team...
  9. Jan 7, 2019 at 9:34 AM
    SgtPuddin
    Mississippi
    Will try that
  10. Jan 7, 2019 at 9:45 AM
    SgtPuddin
    Mississippi
    Brake lights aren’t working.
  11. Jan 7, 2019 at 9:52 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Check your fuses and the brake lights for a short - if you can get the brake lights to work your truck will start.
    I had some extra wiring I did ground out which blew the fuse and then I couldn't start my truck.
    It's weird how Toyota does this - that the start button get's the "ok" permissive from the brake lights - not the actual brake pedal.
  12. Jan 7, 2019 at 9:52 AM
    SgtPuddin
    Mississippi
    Nm they are working
  13. Jan 7, 2019 at 9:54 AM
    SgtPuddin
    Mississippi
    Omg I’m dumb. They are not working
  14. Jan 7, 2019 at 9:57 AM
    SgtPuddin
    Mississippi
    I checked under the dash the one that says tail. It is fine. Which fuse is it under the hood guys?
  15. Jan 7, 2019 at 9:58 AM
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I hope youre using your toyotacare. Have them foot the bill
  16. Jan 7, 2019 at 10:00 AM
    SgtPuddin
    Mississippi
    Just found the fuse under the hood. It was blown. Put in new 10amp and it blew. Wtf
  17. Jan 7, 2019 at 10:00 AM
    SgtPuddin
    Mississippi
    Can I run a bigger fuse just to get it home to check the tail lights
  18. Jan 7, 2019 at 10:02 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. Do you have any mods? Been messing with any wiring? Water in tail light?
  19. Jan 7, 2019 at 10:03 AM
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Sounds like theres a short. Are you in rain/snow?
  20. Jan 7, 2019 at 10:04 AM
    SgtPuddin
    Mississippi
    Winjet tails on since May. Just installed retrofit headlights Friday. No problems till today
