Brake Override Malfunction contact dealership
Discussion in 'Technical Chat' started by Mr-Droc79, Feb 1, 2019.
  1. Feb 1, 2019 at 9:28 PM
    Mr-Droc79
    Mr-Droc79 [OP] Member
    Has anyone experienced a brake override malfunction on a 2016 Tacoma SR5? The car drives at a snail’s pace...
    If so how was it resolved.
    Please help
  2. Feb 1, 2019 at 9:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Low voltage (dead battery) can trigger a lot of codes, things like the ABS module have to report them to the driver.
    Charge the battery, then disconnect it and reconnect, it should clear a good chunk of the faults until you are able to visit the dealer.
    Bikinaz, Taco critter and irayfz6 like this.
  3. Feb 2, 2019 at 2:05 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Go to the dealer
  4. Feb 2, 2019 at 2:10 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  5. Feb 2, 2019 at 4:39 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Did you install any accessories like pedal commander? Try taking it off. I read before that you turn off the truck for 5 to 10 minutes then restart it 10 times . Some says it fixes it. Good luck. Let us know how it goers and how the dealer resolved your issues
  6. Feb 2, 2019 at 5:08 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Welcome!
  7. Feb 2, 2019 at 5:33 AM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    Scan for codes
  8. Feb 2, 2019 at 5:38 AM
    SgtPuddin
    SgtPuddin Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    Mine happened when my aftermarket light got water in it and popped the brake fuse. Truck wouldn’t start when that fuse was popped. Easy fix once I figured out what the problem was. Panic until that point.
  9. Feb 2, 2019 at 6:01 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Three threads by the same person for the same topic....
    12TRDTacoma, NYCTaco52 and tcBob like this.
  10. Feb 2, 2019 at 10:07 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Bikinaz likes this.
  11. Feb 2, 2019 at 12:51 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Saw that. I merged them
  12. May 19, 2019 at 7:10 AM
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    I had the brake override malfunction error yesterday on my '19 SR. I tried turning off and on probably 10 times. I was concerned it was my ovtune, but I got the error to go away. Maybe just a fluke, but I removed my add a fuse for my foglights and it worked. The add a fuse was tapped into the ignition spot. was able to actually drive the truck since it wasn't in limp mode. I still had a check engine light. P219 throttle body actuator. Reset the code, hasn't returned yet. Not sure what or how the add a fuse caused that to happen, but I encourage anyone to remove the add a fuse if they have problems. As I was sitting on the side of the road I saw posts from people with pedal commanders causing issues but I have ovtune and it's a bit harder to remove unless you have a laptop and an internet connection. I'll chime in again if the issue returns, but I'm finding a different spot for my add a fuse.
  13. Jun 15, 2019 at 3:35 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Just happened to me today. First day on the 87 base tune. Drove great for about 20 miles with a couple stops and re-starts. Then down along country road boom CEL, Trac off, and brake override malfunction. Truck drove like shit. Pulled over, shut down and started back up. No more brake malfunction message on the MID but still CEL and Trac off lights. Drove home cleared code (P2119) and been ok since. WTF? Anything to do with ovtune? Or is my throttle sensor bad...and yours. No add a fuse here.
  14. Jun 15, 2019 at 10:07 PM
    Shellshock
    Iowa
    Nope nothing to do with tune. @Cav_BluTRD had the same issue, it was sticking throttle body and replaced under warranty.
  15. Jun 16, 2019 at 7:29 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    What @Shellshock said. No tune issue. Stuck throttle body.
  16. Jun 16, 2019 at 6:17 PM
    hchad18
    hchad18 New Member
    Ha this exact thing happened after approximately 30 miles on the OVtune 87 base tune. Got it out of limp mode. Put the stock tune back in, drove it for a couple days and the put the 91 base tune in and no problems with it yet.
  17. Jun 16, 2019 at 7:38 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Well that's hard to swallow given less than 300 miles on the truck. Happened again today but took like 3 times to clear the code with my scanner. Got back home and flashed back to stock 04B31. I guess a visit to the dealership is in order. I'll take a look at the throttle valve tomorrow. This sucks! Truck is F'ing dangerous when this happens. Can't leave home without the scanner.
    I really miss my 2003 now. Especially the actual throttle cable! And the manual tranny....
  18. Jun 16, 2019 at 7:41 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    How many miles without issues? This shit happened twice in two days now. Only about 5 miles on stock tune so far.
  19. Jun 17, 2019 at 11:39 AM
    hchad18
    hchad18 New Member
    I probably have over 100 miles on the 91 octane base tune now.
  20. Jul 1, 2019 at 12:55 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Happened again today on my way home from the dealer! Taking it back. Haven't cleared codes...
    uploadadventure likes this.
