Brake Override Malfunction contact dealership
Discussion in 'Technical Chat' started by Mr-Droc79, Feb 1, 2019.
  1. Dec 27, 2019 at 3:49 PM
    #61
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    I have an appointment next week to bring the truck in. I’ll report back with my findings.
  2. Jan 1, 2020 at 5:31 PM
    #62
    nwflsr4x4
    Donny
    Pensacola Florida
    Of course they can’t find anything and won’t move forward unless they see the codes active. I’m requesting my complaints in writing because I feel that it’s a safety concern and should an accident take place, Toyota will be at fault because they were aware of the issue. Maybe that will help escalate the situation, but I doubt it.
    El Chivo Norteño likes this.
  3. Jan 1, 2020 at 5:37 PM
    #63
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    This was the exact party line they gave me when it happened the last time. Told me to drive it in to them, or any dealership the next time it happens if I was on a road trip.
  4. Jan 1, 2020 at 6:04 PM
    #64
    nwflsr4x4
    Donny
    Pensacola Florida
    I keep telling them that’s the problem. You can’t drive it when it’s in limp mode. On a road trip is the worse case scenario because they’d have to tow the truck while also providing me with transportation. But that’s when it happened last, I was two states away.
  5. Feb 14, 2020 at 4:33 PM
    #65
    AKMT
    AKMT Member
    Any developments guys? Just happened to me. Truck is at 5,500 miles. Running the 87 ovtune. Planning to go get the computer and flash back to stock.
  6. Feb 14, 2020 at 4:35 PM
    #66
    El Chivo Norteño
    Central Oregon
    If you were running 1.5, get yourself over to the 2.0 beta.
    What year truck and what ECU do you have?
  7. Feb 14, 2020 at 4:59 PM
    #67
    nwflsr4x4
    Donny
    Pensacola Florida
    I had this issue on 2.0 beta also. I’ve been running stock tune for the time being. If it happens in stock tune I’ll know it’s not the tune. I’d rather be tuned, but I have to conduct this test to know for certain.
  8. Feb 14, 2020 at 5:15 PM
    #68
    El Chivo Norteño
    Central Oregon
    I have been told it happens on stock 2019 trucks w/ ECU 04B31. It happened to me 3x times with the 1.5 / 1.5.1 tune. At which time I flashed to stock, until the 2.0 beta rolled out. Flashed to beta and never had an issue up until I traded the truck in for the 20. Post your stock test results when you feel comfortable :thumbsup:
  9. Feb 14, 2020 at 5:41 PM
    #69
    AKMT
    AKMT Member
    Mine is the 04B31 as well. I am running 1.5. Maybe I'll try running the 2.0beta and see how that does, though it looks like it might do the same thing based on post 68. The truck was throwing p2119. Is that consistent with your guys experience?
  10. Feb 14, 2020 at 7:20 PM
    #70
    nwflsr4x4
    Donny
    Pensacola Florida
    yep that’s it.
  11. Feb 14, 2020 at 7:32 PM
    #71
    El Chivo Norteño
    Central Oregon
    Yup that’s the one
  12. Feb 14, 2020 at 7:38 PM
    #72
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Well this isn't good! I've probably racked at least 6k miles on 19770 with no P2119/BOM fubars. Which 2.0 tune? 04B31?
  13. Feb 14, 2020 at 8:07 PM
    #73
    nwflsr4x4
    Donny
    Pensacola Florida
    2.0 04B31 - 2019 Automatic 87 Octane Stock Exhaust
  14. Feb 15, 2020 at 9:14 AM
    #74
    AKMT
    AKMT Member
    How many times have you had the error occur? If you flash back to stock does the problem seem to go away?
  15. Feb 15, 2020 at 9:24 AM
    #75
    nwflsr4x4
    Donny
    Pensacola Florida
    Once at 1400 miles on 1.05 and once at 6000 miles on 2.0. When it happened on 2.0, I flashed to 1.05 and drove less then 5 miles and it happened again so I flashed to stock. That was less then 1000 miles ago.
  16. Feb 15, 2020 at 9:32 AM
    #76
    AKMT
    AKMT Member
    Been good using stock since then? Trying to decide if I should go to the dealer or not...
  17. Feb 15, 2020 at 9:38 AM
    #77
    nwflsr4x4
    Donny
    Pensacola Florida
    In my experience, Unless the error code is active, the dealer cannot help you. They told me to have the truck towed the next time it happens. I miss the tune but kinda hope it doesn’t come back on stock. Mainly because that means my truck is broke and they have no clue how to fix it. I’ll run stock for awhile and see what happens.
  18. Feb 15, 2020 at 9:45 AM
    #78
    AKMT
    AKMT Member
    Gotcha. That was my impression after reading through this thread. I probably have 3k with 1.5 and am bummed the error occured. Maybe I'll flash back to stock and roll that for a while. I'll post if anything related to this subject happens
  19. Feb 15, 2020 at 11:40 AM
    #79
    nwflsr4x4
    Donny
    Pensacola Florida
    If it were just a code that popped up, it would be a non issue for me and I’d run the tune. But since it kills power to the engine it can be a pretty scary situation. Only time will tell if it’s the tune or the truck. If there are future tunes that come out I may try them eventually, but it is what it is.
  20. Jun 8, 2020 at 7:16 PM
    #80
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    Just had the brake override issue come up. I was adding bed stiffeners and had the tail lights out. I’m running 2.0 right now. Any suggestions on how to reset the override? I should add that I did disconnect the battery.
