Brake Override Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProjectTgen3, Jul 19, 2017.
  1. Jul 19, 2017 at 3:16 PM
    ProjectTgen3
    ProjectTgen3 [OP] Well-Known Member
    Keandrew
    Pennsylvania
    2016 Super White Tacoma TRD Off-Road
    Bilstein 5100 with OME Lift Springs Fox Performance rear 2.0 shocks DX4 Tuff wheels 17x8.5 -6 Falken Wildpeak A/T3W 285/70/17 RCI Rock Sliders
    Welp tried installing new LED tail lights in the 3rd gen. 1 was already installed 2nd one had to be replaced OG. Everything was fine and when the second tail light came in. Truck won't start. Brake Override Malfunction came on. ACC works, front headlights(HID) works, LED dogs works. Won't start. Saw that the 7.5 was blown, prepared that but still won't start. HELP! Really don't want to take it to a dealership. I've tried putting the old tail light back. All other lights are working except rear driver side even with new fuse.
  2. Jul 19, 2017 at 3:28 PM
    FHC
    FHC Well-Known Member
    disconnect the battery for a few minutes
    ProjectTgen3[OP] likes this.
  3. Jul 19, 2017 at 3:36 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Are these the "wingjet" lights?
    ProjectTgen3[OP] and beergeek like this.
  4. Jul 19, 2017 at 4:06 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    Did that
  5. Jul 19, 2017 at 4:07 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yup and already emailed them about a full refund. I also thought it may be the new reverse lights cause they weren't put in until the second tail came in.
  6. Jul 19, 2017 at 4:10 PM
    FHC
    Look through the owner's manual?
  7. Jul 19, 2017 at 4:14 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Check all your fuses. Pretty sure you blew the brake light fuse I'll can't remember what circuit it's tied into. Let me see if I can look it up
    ProjectTgen3[OP] and FHC like this.
  8. Jul 19, 2017 at 4:17 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yup did that only shows a picture of the code and to see the dealership haha
  9. Jul 19, 2017 at 4:18 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    I tried the tail fuse from under the dash. And it's only a 7.5
  10. Jul 19, 2017 at 4:21 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There will be another. Pull each one and find what one is blown
  11. Jul 19, 2017 at 4:23 PM
    FHC
    You may need to test them with an ohmmeter, you can't always tell by looking at them.
  12. Jul 19, 2017 at 4:54 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    I'll try to find another blown fuse but I really hope I can get it to start
  13. Jul 19, 2017 at 4:56 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    The truck won't start if you blow a brake light fuse?
    tcjacado and ProjectTgen3[OP] like this.
  14. Jul 19, 2017 at 4:58 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    Exactly! For whatever reason when the tail lights went in i tried starting the truck and it won't start. Then the brake malfunction code came on.
  15. Jul 19, 2017 at 5:00 PM
    FHC
    Is the truck in park?
  16. Jul 19, 2017 at 5:01 PM
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yup
  17. Jul 19, 2017 at 5:04 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Is this a new feature in the 3rd gen, or will this happen to my 2nd gen also?
  18. Jul 19, 2017 at 5:07 PM
    JeffreyB
    Jeff
    Holy shit. Well it'll keep you from getting a ticket or rear ended. That is really stupid though, if something like that goes out you could be stuck somewhere. I'd be certain to carry some spare fuses.
  19. Jul 19, 2017 at 5:08 PM
    FHC
    It almost sounds like the short caused another problem other than a blown fuse!
  20. Jul 19, 2017 at 5:12 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I would get my multimeter out and check more then just the brake light fuse.
    shakerhood and ProjectTgen3[OP] like this.
