Brake Override Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProjectTgen3, Jul 19, 2017.
  1. Jul 19, 2017 at 5:39 PM
    #41
    ProjectTgen3
    ProjectTgen3 [OP] Well-Known Member
    Keandrew
    Pennsylvania
    2016 Super White Tacoma TRD Off-Road
    Bilstein 5100 with OME Lift Springs Fox Performance rear 2.0 shocks DX4 Tuff wheels 17x8.5 -6 Falken Wildpeak A/T3W 285/70/17 RCI Rock Sliders
    Cause the Brake Over ride Malfunction code. Not like I can just keep the car sitting or have an error code. The tail lights I have no idea what else can be done rn.
  2. Jul 19, 2017 at 5:43 PM
    #42
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Fuse(s), relay, or ECU
    tomwil and ProjectTgen3[OP] like this.
  3. Jul 19, 2017 at 5:45 PM
    #43
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    According to this diagram, you have 2 fuses to check. Have you checked both of them?
    ProjectTgen3[OP] likes this.
  4. Jul 19, 2017 at 5:46 PM
    #44
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not on a push button. You need to step on the brake to start the truck. Also the brake circuit powers the shift release, so the shifter will also be locked
  5. Jul 19, 2017 at 5:47 PM
    #45
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yup it is locked
  6. Jul 19, 2017 at 5:54 PM
    #46
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Gotta be another blown fuse. Just test them or take a closer look
  7. Jul 19, 2017 at 5:54 PM
    #47
    Herniator
    Edmonton
    Do you have a meter or are you checking them visually?
  8. Jul 19, 2017 at 5:59 PM
    #48
    ProjectTgen3
    Keandrew
    Pennsylvania
    Visual
  9. Jul 19, 2017 at 6:00 PM
    #49
    ProjectTgen3
    Keandrew
    Pennsylvania
    So far only see 1 and I've referred to the diagram
  10. Jul 19, 2017 at 6:11 PM
    #50
    ProjectTgen3
    Keandrew
    Pennsylvania
    Correction I did find the STOP fuse blown in the engine bay fuse box. Battery has been disconnected for a bit about to start it.
  11. Jul 19, 2017 at 6:20 PM
    #51
    Herniator
    Edmonton
    Good luck. Keep us posted.
  12. Jul 19, 2017 at 6:21 PM
    #52
    ProjectTgen3
    Keandrew
    Pennsylvania
    She starts!!!!!
    tcjacado, FHC and shakerhood like this.
  13. Jul 19, 2017 at 6:23 PM
    #53
    Herniator
    Edmonton
    Awesome. It should drive ok now. Take it for a short test drive.
  14. Jul 19, 2017 at 6:23 PM
    #54
    ProjectTgen3
    Keandrew
    Pennsylvania
    No that's it night out I can for sure see what lights are working. So rear tails don't light up at all. Passenger rears does turn signal and brake lights on. Driver side hyper blinks and no lights are on. DRLs are not on at all. HIDS works and front LED dogs work. Did not check the drl fuses.
  15. Jul 19, 2017 at 6:25 PM
    #55
    Herniator
    Edmonton
    Which lights do you have in the truck. Factory or the aftermarket?
  16. Jul 19, 2017 at 6:25 PM
    #56
    ProjectTgen3
    Keandrew
    Pennsylvania
    The rears are all factory now. Only after market is the front
  17. Jul 19, 2017 at 6:26 PM
    #57
    Herniator
    Edmonton
    Aftermarket LED's are known to hyper flash. You need a resistor installed to stop that.
  18. Jul 19, 2017 at 6:28 PM
    #58
    ProjectTgen3
    Keandrew
    Pennsylvania
    Even though it's only happening on the rear tails? Only LEDs are the fogs. Rears have none and the headlight is HID. Didn't even put leds in the front turns
  19. Jul 19, 2017 at 6:28 PM
    #59
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    And to.make sure the power is out. Take the positive and neg. Off. Then touch
    So are u back on for the take over?
  20. Jul 19, 2017 at 6:33 PM
    #60
    ProjectTgen3
    Keandrew
    Pennsylvania
    Haha nope. I still gotta make sure it won't happen to me when I'm out there especially on trail I don't want to go into limp mode or have it turnoff. But if they give me a rental
