Brake override malfunction?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by btrumpatori, Oct 7, 2020.
  1. Oct 7, 2020 at 4:41 PM
    btrumpatori
    btrumpatori [OP] Well-Known Member
    Driving home from work today - probably 10 miles into a 12 mile commute, my truck lost acceleration - If I floored the gas the RPM stayed just under 2 and I maxed out at about 25 mph. I limped home and just before hitting my neighborhood, my check engine light, TRAC light and an error message that read "brake override malfunction" popped up.
    I've got 13K miles on a 2020 TRD Sport. I've got an aftermarket Pro grille that I've had on it since it was a month old with ZERO problems with the TSS sensor. I've got raptor lights that have been on for the last 6 months without issue. I've had a pedal commander installed, similarly, for ~6 months without issue.
    I went back out after it sat in the driveway for 10-15 min and restarted - check engine light is still on, but no override malfunction message and it seems to accelerate normally.
    Any experience with this? I am taking it in to the dealership tomorrow, but am curious if the mods could be called out as a possible cause (in spite of the fact that they've been installed for months without issue).
    Tullie D likes this.
  2. Oct 7, 2020 at 5:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It absolutely does not matter if the mod was installed six minutes ago or six years ago. A mod is a mod and just because it went good for awhile does not mean something didn't happen.
    Take it to a dealership, have it evaluated and see.
    Tullie D, Skydvrr and Chew like this.
  3. Oct 7, 2020 at 5:37 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Mods definitely could be a problem
    Chew and Tullie D like this.
  4. Oct 7, 2020 at 5:40 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I remember reading about this . . .
    Brake Override Malfunction Error
    Not saying you've got the same problem, but it's something to check.
  5. Oct 7, 2020 at 5:49 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    As @Tullie D stated, could be pedal commander.
    Take note of the orange/gold notice(s) in the attached file.
    I don't know if pedal commander can cause further issues if left installed as I have not read up on it much, but it would be a likely candidate in my opinion and I would suggest removing it for troubleshooting. At a minimum, remove it before taking it to the dealer.
    Tullie D, btrumpatori[OP] and Skydvrr like this.
  6. Oct 7, 2020 at 6:01 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    I've definitely read about this with pedal commander.
    I pretty sure the problem happens when you change the setting while one the accelerator.
    I'm sure there got to be a bunch of threads on here about it.
  7. Oct 8, 2020 at 12:21 PM
    btrumpatori
    Many thanks. Must have been the Pedal Commander. I knew I wasn't supposed to change settings while moving and I don't think my leg hit it (based on how it is secured under the steering wheel) but disconnecting it, seemed to fix the issue completely. I will try to hook it back up tonight to see if it reverts.
