Brake override system malfunction.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trdpro85, Feb 28, 2019.
  1. Feb 28, 2019 at 9:34 PM
    Trdpro85
    Trdpro85 [OP] Well-Known Member
    2018 TRD PRO
    Replaced battery because it tested bad. However I can't put the truck in gear to move it. If I hold the start button long enough the engine will start. Has anyone had this problem with the third gens? I'm kinda screwed because I'm in a one car garage in a tight space at an apartment complex. Can't get transmission out of park.
  2. Feb 28, 2019 at 9:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ScottyR likes this.
  3. Feb 28, 2019 at 9:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Pop the small cap above the shifter and use a long screw driver to disengage the park lock.
  4. Feb 28, 2019 at 10:00 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Try what Bishop84 suggests. In Owner's Manual p.205, When shifter doesn't move.
    Flash1034 and Rujack like this.
  5. Feb 28, 2019 at 10:30 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    It’s under warranty. Have Toyota pick it up.
    Modesto Tacoma likes this.
  6. Mar 1, 2019 at 4:25 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Sucks to hear OP. Hope you get it in gear and driving. Keep us posted.
    One more reason I’m glad I have a manual...
    Tacoma1818, shakerhood and elduder like this.
  7. Mar 1, 2019 at 4:50 AM
    daves-cement-taco
    daves-cement-taco Member
    Had the same issue. Check the STOP fuse under the hood.
  8. Mar 1, 2019 at 4:55 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Interesting to know. Is that only for push start or key also ?
  9. Mar 1, 2019 at 5:55 AM
    Trdpro85
    2018 TRD PRO
    Will do thanks. My brake lights don't work. Nor do my running. All other lights come on.
  10. Mar 1, 2019 at 7:56 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    So . . . you're thinking that something happened with the battery change?? Who changed it? Negative off first, and on last?? Did you use anything to keep power on the ECU during the change?
    Keep us posted. Not sure what could have caused this.
    G.
  11. Mar 1, 2019 at 8:32 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Good point about keeping power to the ECU. Used to use a 9v battery/cigarette lighter insert to keep the Frontier ECU powered during battery change... is that even OK to do on these trucks?
  12. Mar 1, 2019 at 8:34 AM
    Garyji
    Gary
    Yes.
    G
  13. Mar 1, 2019 at 9:07 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    All automatics with floor shifters should have that little removeable cap.
    Whitetail Assassin likes this.
  14. Mar 1, 2019 at 9:24 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Thats the easy part.... 98% chance he hooked the battery up wrong, even if momentarily.
    I was in the car business and lot porters did this more frequently than you'd imagine. Seems there's more protection in modern vehicles though so hopefully OP just has to replace some fuses and be ok.
    I've seen this happen to cars from the 90s and the entire ECU and wiring harness would fry. Now it seems its mostly just replacing all the fuses that blow.
  15. Mar 1, 2019 at 10:45 AM
    Trdpro85
    2018 TRD PRO
    Battery tested bad. In fact when I pulled it the bottom had acid. The guy told me even after he tried charging it it was only at 40% of the rated cold cranking amps that was part of the problem. The other issue was the LED tell lamps. The first time it popped the 10 amp stop fuse. Once I changed that out I had brake lights but then it kept popping the tail lamp 7.5 fuse every time I would turn on the headlights. As soon as I put the OEM lamps back in problem was solved. Moral of the story third generations don't do LED very well.
  16. Mar 1, 2019 at 10:51 AM
    Garyji
    Gary
    I have said this before. When you post about problems, it would be very helpful if you told us about mods in the first place! Tons of "I fucked with my lights and now my truck won't work" threads.
    Glad you figured it out.
    G.
    shakerhood likes this.
  17. Mar 1, 2019 at 10:51 AM
    Trdpro85
    2018 TRD PRO
    Thanks for all the help. As far as taking it to the dealership I was dreading that because talking to them this morning before I did more investigating they could care less that a wrecker couldn't easily get to it. The guy didn't understand why I was so worried about just getting it up there. Even try to tell me that if I couldn't get the transmission to release that it really wouldn't hurt it to drag it in park just to put it on the bed. Like I told him it might not hurt it right now but you can't tell me pulling against the parking pawl is good for it. Not only that are you going to take responsibility if something happens? He could not give me a straight answer lol.
  18. Mar 1, 2019 at 11:00 AM
    Whitetail Assassin
    Tedric
    West Virginia
    When you mentioned the problem the first thing I thought of was aftermarket bulbs. There are a couple of threads related to bulbs and stuff like this happening. Since you didn’t mention it I figured maybe it was a fluke. Search the topic and you will see that others have had the same issue. Hasn’t been that long ago that I saw the most recent one. No LED bulbs for me that’s for sure. Between hyperflashing and this kind of stuff I am not risking it.
  19. Mar 1, 2019 at 11:05 AM
    Trdpro85
    2018 TRD PRO
    Absolutely I'm done with all that. Not really crazy about the LED I was just wanting the smoked lights. However it's not worth the headaches I can promise you that. I was reading the instructions and on the very back page it talked about it was normal when you first hooked it up for it to blow both fuses. I was thinking to myself that's not normal to blow fuses you have problems. I understand every once in awhile fuses can go bad but if it continues to blow which kept happening to me you have bigger problems. Going to try to return these.
  20. Mar 1, 2019 at 1:01 PM
    Trdpro85
    2018 TRD PRO
    Also the one weakness that I found with this truck is the OEM battery. Total junk. Only 6 months old and it already bit the dust. My brother's second gen had the same problem about a year later as well when it was new.
