Brake Pad Grease Points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LJrubi, Nov 20, 2019.
  1. Nov 20, 2019 at 6:37 PM
    LJrubi
    LJrubi [OP] Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    So I upgraded the brake system today with some nice OEM toyota cryo rotors and the red TRD performance brake pads. I took the shims off the pads and put some grease between the pad and shim. I also cleaned the pins that slide through the caliper and put a light coat of grease on those too. Should I have greased anything else?
    Also, does it matter what side you install the pad with the wear indicator? I put mine on the inside.
  2. Nov 20, 2019 at 6:44 PM
    Bishop84
    Bishop84 Well-Known Member
    Pad squealer is inside. On the left for drivers side and on the right passenger side. It's not critical, I wouldn't tear it apart if they are switched.
    I use light grease between shims, and on the edges of the pads that ride against the calipers. Pins as well.
    TnShooter and whatstcp like this.
  3. Nov 20, 2019 at 7:08 PM
    LJrubi
    Dan
    North West NJ
    No grease on the outside of the shim that makes contact with the pistons correct? Leave that dry?
  4. Nov 20, 2019 at 11:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do the Indicators go on the Trailing or the Leading Edge of the Pads?
    I usually install them they way the old ones come off, but have seen the both ways.
    Or is it vehicle specific?
    Thanks
