Brake Pad Slap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by krue92, Sep 19, 2016.
  1. Sep 19, 2016 at 9:15 AM
    krue92
    krue92 [OP] Well-Known Member
    Nebraska
    I have been getting a brake clunk almost everytime when switching to drive or reverse and then hitting the brake. It only usually happens the first time going in that direction. Last night I replaced the caliper pins and added another spring to the top of the caliper like others have done. It doesn't seem to have helped any for me though. The pads are only a year old too. Any other ideas to fix this issue or could it be something else related the the brakes?
  2. Sep 19, 2016 at 9:18 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Its just brake pad play inside the calipers. Simply ignore it
  3. Sep 19, 2016 at 9:22 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
  4. Sep 19, 2016 at 9:36 AM
    krue92
    Nebraska
    I did have some of that, but didn't apply any to the pads. I don't remember this noise until more recently. I think probably because the pads were brand new last year, so it never did it then.
  5. Sep 23, 2016 at 9:20 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    It's annoying. I keep meaning to look into a solition and am reminded everytime i hear them.
  6. Sep 24, 2016 at 6:15 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Pull the slide pins and grease them with the correct grease.
  7. Sep 24, 2016 at 7:47 AM
    Pigpen
    Dan
    Northwest Montana
    A touch of brake grease on the back side of the pad should stop the slap - I've just been ignoring mine for years.
