Brake pads and rotors in BAD shape
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Incubus311, Aug 5, 2022.
  1. Aug 5, 2022 at 9:26 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Time for a nice brake upgrade. Never let a disaster like that go to waste.
  2. Aug 5, 2022 at 9:50 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Wow, those aren't brakes.
    Pull full service, clean up everything, install new brake pads, rotors, a little bit of grease on the pins will help. Post some pics when done. Good luck with your truck.
  3. Aug 6, 2022 at 3:24 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    So far so good, the spring cleanup works. No binding that I can discern, and pad wear is even. The pins come right out too.
  4. Aug 6, 2022 at 4:31 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My 19 year old tundra had better looking calipers and pad pins than the ones in the op's pictures. Where has the truck been sitting, in a swamp?
    Incubus311[OP] and TacoManOne like this.
  5. Aug 6, 2022 at 4:43 AM
    MOC221_
    Frank
    Rust belt.
    Incubus311[OP] likes this.
  6. Aug 6, 2022 at 4:48 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    55 k miles is good for brakes especially in rust belt
  7. Aug 6, 2022 at 5:31 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Thanks for posting real mountain pictures. I go into ID and MT and they have real mountains there too! LOL.
    eurowner[QUOTED] likes this.
  8. Aug 6, 2022 at 5:44 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They were worn out 5,000 miles ago! That little metal tab should have been squealing long before you got to that point!
  9. Aug 6, 2022 at 6:08 AM
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    I'm fixing to do brakes this morning, how are the calipers pushed in? Can I do it with a c-clamp or so I need that 3/8"-drive nub box I used on my 1992 Toyota?
  10. Aug 6, 2022 at 6:31 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Leave the old pad against the pistons so they both go in together. Squeeze pistons in. Replace with new.pads.
  11. Aug 6, 2022 at 6:33 AM
    TruckGuy63
    Gilbert
    New York
    c-clamp use the back side of the pad to push both pistons in. The right way to do it is get a empty plastic bottle. Fill it up partially with brake fluid. Put a clear hose on the bleeder valve nice a tight .
    Loosen the bleeder valve with the other end of the hose submerged in the brake fluid and push the pistons in. Once done close the bleeder valve. Just Remember once the new pads are on and buttoned up . Put you foot on the brake pedal and the fluid level on the master will go down. Add fluid and pum tight keeping the master fill. Repeat on other side. You don’t want to put that nasty fluid in the calipers back up in the master cylinder.
  12. Aug 6, 2022 at 6:42 AM
    barcelona7568
    CO
    16 DCLB, Stock
    Thanks fellers. What is the logic for submerging the open end of the bleed waste hose?
  13. Aug 6, 2022 at 6:47 AM
    ChainsawCharlie
    ChainsawCharlie Well-Known Member
    Sean
    New Hamster
    2017 TRD OR DCSB Quicksand
    3 Cans of Plasti Dip, Rain-X 2 in 1 all season wiper fluid, "SAWDUST IS MAN GLITTER" sticker, Mobtown rear bumper, Pioneer AVH 2440NEX
    Probably to keep air from getting into the caliper.
  14. Aug 6, 2022 at 6:48 AM
    TruckGuy63
    Gilbert
    New York
    Actually I gave you wrong info .Fill the master cylinder up before you pump the brakes . It will be low already because your brakes are so worn . Unless someone filled it up at a service .That is always a big red flag that you need brakes when the master cylinder is low
  15. Aug 6, 2022 at 6:54 AM
    #35
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    One of the first things I was taught when I was learning to drive is the better driver you are, the less you need your brakes. I’m not throwing shade at OP. I’m saying, when one makes an effort to pay attention to traffic patterns and anticipate the moves of others around you, you don’t need your brakes as much. Of course most people nowadays are very special and above the law so they can’t be bothered to put their phone down and use their blinker, much less try to analyze traffic. Oh well, stupid people suffer stupid people problems. Glad that’s not me.
  16. Aug 6, 2022 at 7:55 AM
    #36
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    the more aware you are the more you realize not many people are aware of their surroundings
  17. Aug 6, 2022 at 8:31 AM
    #37
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    you should be able to hear when the pads are getting low unless you are deaf.
  18. Aug 6, 2022 at 9:28 AM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
    That is why the OPs pads have no braking material left and now metal on metal.
  19. Aug 6, 2022 at 9:29 AM
    #39
    eurowner
    eurowner Duke Sky
    Scoty
    It's not cocaine, though make a crap ton of money.
    54k and still have a lot of life left on my OEM pads/rotors/drums/shoes.
  20. Aug 6, 2022 at 9:43 AM
    #40
    barcelona7568
    CO
    16 DCLB, Stock
    Incubus311[OP] and Key-Rei like this.
