brake pads and rotors
Discussion in '1st Gen. Tacomas (1995-2004)' started by PappaSmurf, Dec 15, 2011.
  1. Dec 15, 2011 at 8:58 AM
    PappaSmurf
    PappaSmurf [OP] Member
    Robert
    NC
    03 Tacoma SR5 Step Body
    Any suggestions for pads and rotors for my 2003 Tacoma? Toyota parts or something else? replace just the pads or rotors too? 130k miles, no metal on metal, just thinning pads.
  2. Dec 15, 2011 at 9:11 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I have 115,000 on mine. I just did front pads/rotors. I went with OEM pads that I got off ebay, I think they were about $37.
    As for rotors, I couldn't have them turned as they were not within specs (girlfriend drives truck to work at night and she loooooooves to ride that left pedal), so I went with OEM Brembo replacement rotors (nothing fancy, just the round, flat ones :), about $45 each if I recall.
    Very happy with the setup. No noise, plenty of power. Can't go wrong with OEM pads and Brembo rotors.
  3. Dec 15, 2011 at 3:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I've finally found he best setup I've ever ran......and what I'm using currently and will stick with.....powerslot rotors and Wagner thermoquiet ceramic pads. Awesome bite,no pedal fade either with them.
  4. Dec 15, 2011 at 4:47 PM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    Definately agree with the thermoquiet pads, but I went with bosch quietcast rotors because they have a lifetime warranty! Only been on for 2 months, but they still look new!
  5. Dec 15, 2011 at 8:08 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    Lifetime rotors are ok if you don't mind changing them. But make sure they are made with good metal. Some brands will say in the description something to the effect of "Made with better metal." That is what you are paying for w/ rotors. I'm running EBC replacement (no slots/holes) rotors and I like how they've lasted. Price wasn't bad on them either.
    When I was running the stock setup I burned up a set of powerslots in no time. Immediately following that I went to Tundra calipers.
    On pads I have liked EBC green stuff, and Akebono. Good results with both. I had a really bad set of "Top of the line" NAPA pads.
  6. Dec 15, 2011 at 8:23 PM
    homer96
    homer96 Well-Known Member
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    Hella 500s, AFE pro dry, Pioneer head unit and Polk audio 650 speakers,
    I have the Wagner thermoquiets and I love them
  7. Dec 16, 2011 at 5:39 AM
    mmiller2002
    mmiller2002 Member
    Fort Worth, TX
    2004 Double Cab 2wd
    For rotors, Autozone or similar solid blanks should be fine, and they have a lifetime warranty. I've used them on my subaru wrx on the track with no problems. They're just pieces of iron. I'm trying their ceramic pads this weekend, also lifetime warranty. Make sure you use the brake grease on the backside and shims to eliminate noise.
