brake pads for 2001 pre runner v6
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdarcy, Dec 28, 2013.
  1. Dec 28, 2013 at 6:01 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    I purchased ebc greenstuff 6000 series brake pads for my 2001 Tacoma v6 and they have different clips at the bottom than the old ones that I removed do. Does anyone know if the 2001 pre runner with a v6 uses different pads than the other Tacoma's do? Has anyone put EBC Greenstuff pads on a 2001 Tacoma V6? Any insight into the proper orientation or function of the clip like things on the bottom would be appreciated.
  2. Dec 28, 2013 at 6:03 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I put ebc green stuff pads on my 2000 v6 4x4 and had no issues.
  3. Dec 28, 2013 at 6:19 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    Do you remember which pad goes on which side of the caliper?
  4. Dec 28, 2013 at 6:21 PM
    2000GTacoma
    Snow Hill NC
    I don't think it matters. They are the same.
  5. Dec 28, 2013 at 6:27 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    were the bottom parts of the pads different? I will post pictures in a minute.
  6. Dec 28, 2013 at 6:28 PM
    2000GTacoma
    Snow Hill NC
    The ebc pads looked identical in shape to the Toyota pads I pulled off.
  7. Dec 28, 2013 at 6:37 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    I am trying to figure out which pads go where in the calipers. Do you know how yours were? My old ones were different. The black ones are the two pads from the passenger side rotor and neither of them has that metal thing at the bottom in the middle, like the green EBC pads do.
  8. Dec 28, 2013 at 6:43 PM
    2000GTacoma
    Snow Hill NC
    The metal piece is just the little piece that scrapes against the rotor when the wear down and squeal to warn you that your pads are getting low on material. Doesn't matter if you install it inside (towards the truck) or outside (towards the wheel).
  9. Dec 28, 2013 at 6:47 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    Thanks for all your input. Do you think it maters that the old pads are different from these new ones?
  10. Dec 28, 2013 at 6:54 PM
    polack
    polack Well-Known Member
    does not matter at all. The new pads you have just have squealers on them. just put on squealer per side.
  11. Dec 28, 2013 at 6:56 PM
    2000GTacoma
    Snow Hill NC
    x2
  12. Dec 28, 2013 at 7:15 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    Can you confirm that the squealer can be on either side of the caliper. (inside or outside)
  13. Dec 28, 2013 at 7:20 PM
    polack
    either side.
  14. Dec 28, 2013 at 7:24 PM
    jdarcy
    jdarcy [OP] Member
    2001 Prerunner
    Thanks
