Brake pads, need advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ads5689, Jun 3, 2017.
  1. Jun 4, 2017 at 10:20 PM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    I've had good success with akebono ceramic, terrible experience with hawk hps. Followed bedding procedure precisely and warped three sets of rotors before I gave up and went with akebono...smooth sailing after that.
    For those recommending oem, akebono is the closest I have found to the oem lack of sound and dust, but also around 45$ per set on Amazon compared to 80-90$ for oem
    Food for thought
    Partzguy likes this.
  2. Jun 4, 2017 at 10:52 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Mine over heated this weekend going down a steep mountian with rtt and camping gear in the back. I almost crashed (couldn't stop plus smoke from the pads.) and the oem pads only lasted 18k miles. Lots of hills in San Francisco.
    I have akebono with oem rotors that were resurfaced that was installed last week.
    gthupman likes this.
  3. Jun 9, 2017 at 11:16 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Nice 100K. I am at 70K and was thinking it is time. Rear pads changed at 30K and going strong. Will probably due OEM as well.
  4. Jun 11, 2017 at 12:35 PM
    xpert1111
    xpert1111 Well-Known Member
    Central NJ
    2018 DCLB Sport
    Find it amazing front pads lasting over 100k. 2011 and on my 3rd set at 92k
  5. Jun 15, 2017 at 2:10 PM
    Blue Flames
    Blue Flames New Member
    Greg
    2014 Tacoma 4wd Extra Cab
    I have at 14' SR5 with auto trans. Needs brakes at 55k. Ordered the Powerstop kit K137 from Amazon. Does the "rental" kit from O'Reilly have the correct tool to retract the calipers, or do I have to buy this one on Amazon?
  6. Jun 15, 2017 at 2:50 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    No need for a special tool. You can use two flat top screw drivers to push the pistons back in before removing the pins, pads and rotors.
    spitdog and TheCookieMonster like this.
  7. Jun 15, 2017 at 4:44 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I used two big flat pieces of 1/4" metal and a pry bar to force all 4 pistons back at once. Worked like a charm. Bought Napa brand pads. No complaints. My old pads lasted 296,000kms. And there was still about 2-3mms of pad left.
  8. Jun 15, 2017 at 5:21 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Everyone has their opinion so I will play along. I just put brembo rotors, hawk lts pads and stop tech ss braided brake lines on and I am happy
  9. Jun 15, 2017 at 5:22 PM
    taco2010trd
    Tampa, Florida
    This is what I did flat screwdriver on the old pads
    outlawtacoma likes this.
  10. Jun 15, 2017 at 5:24 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I just put new pads/rotors on Monday. I went with Powerstop pads and Centric rotors.
    Works like a charm.
  11. Jun 15, 2017 at 5:28 PM
    taco2010trd
    Tampa, Florida
    Dont forget to check your rear drums too. One of mine wasn't functioning properly and even after new front brakes the brake pedal travel was excessive until the rear was fixed.
  12. Aug 10, 2017 at 8:54 AM
    Mike06toyota
    Mike06toyota Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    Do you think the oem rotor or a regular autozone rotor matter? Do you think you gain anything but paying for the oem rotor or is just the pads that matter for stopping?
  13. Aug 10, 2017 at 11:29 AM
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    Ask yourself this, what are you trying to accomplish with aftermarket brake pads? Have you faded your OEM brakes or are otherwise unhappy with them? If not "upgraded" parts are often a downgrade. Everything from shorter pad life, brake dust, noise and degraded performance when cold are possible.
  14. Aug 10, 2017 at 11:47 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Do any of y'all check the runout when you do rotors? I know you should... but does anybody actually do it?
  15. Aug 10, 2017 at 11:50 AM
    #35
    Mike06toyota
    Santa Clarita
    I get the oem pads but I wanted to know if the rotors from Toyota are worth getting or should I get some upgrades one
  16. Aug 10, 2017 at 11:53 AM
    #36
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I can get the OEM rotors for $60, that's probably what I'm gonna do. Mine have lasted fine until I had them turned... then they warped. I'm thinking about doing the 5th gen 14WA caliper and 338x32mm rotor upgrade.
  17. Aug 10, 2017 at 11:57 AM
    #37
    Mike06toyota
    Santa Clarita
    I got about 3 to 4 hundred pounds extra on my truck and if you add me another 215 and I just use the duelist lifetime warranty top tier brake pads and I just don't think it's stopping very well. Also ton note I changed my rotors to autozone after market about 15 k mikes ago or so.
  18. Aug 10, 2017 at 12:04 PM
    #38
    Taco TRQ
    TuRDTaco
    My previous statement applies to the rotors too as well as most other things. Toyota put a lot of thought into your brakes and people rarely complain about them. "Upgraded" parts will often cause you hassle, degraded life, etc. For example, drilled rotors crack. Slotted rotors will degrease pad life.
  19. Aug 11, 2017 at 9:09 PM
    #39
    cbrcolin
    cbrcolin Well-Known Member
    Colin
    THOUSAND PALMS, CA
    19 QUICKSAND 7545
    NONE YET
    Personally I would stick with the OEM brake rotors, many of the aftermarket rotors are cheap junk. If you want to get the longest life out of your rotors just have them resurfaced if you have a brake vibration, not necessarily when you change brake pads. They have a minimum thickness so they can only be resurfaced a number of times.
  20. Aug 11, 2017 at 9:14 PM
    #40
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    LOl, rotors... for sure! Pads, at 144,000 miles I have changed them 3 times, maybe 4! Rear brakes still look almost brand new! You also have to consider tire/wheel weight and the type of driving you do.
