Brake pedal binding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JAMC, Jul 26, 2019.
  1. Jul 26, 2019 at 3:28 AM
    JAMC
    JAMC [OP] Well-Known Member
    SW Ontario
    2019 TRD SPORT DC LB
    iboards BFmx4
    When the brake pedal is pushed it feels as though it is binding or stiff at the pivot point(linkage). Once past that point it is smooth. Brakes work fine as far as stopping, but less stopping power due to rear drum brakes(compared to disc all the way around on the car). Not sure if it is rubbing or is there an electric switch or switches for brake lights or whatever connected to the pedal linkage. I guess I should look myself but it is under warranty. Just wondered if this is normal?
  2. Jul 26, 2019 at 7:12 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Never noticed that on mine. You may want to take it in and show them what you are experiencing.
  3. Jul 26, 2019 at 11:29 PM
    Vyprdad
    Vyprdad Well-Known Member
    David
    2019 Tacoma TRD Off Road
    I have the same exact thing in the one I just bought a week ago. Thought that is a weird feeling. Like a light rough spot then smoothes out.
  4. Jul 27, 2019 at 3:48 AM
    JAMC
    SW Ontario
    iboards BFmx4
    Its rather annoying every time I hit the brakes. Might it be the button switch(or whatever type) for the push button start? Naturally the dealership didn't think it was anything out of the ordinary. Maybe over time it will loosen up. I have less than 600 miles on it.
  5. Jul 27, 2019 at 6:28 AM
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    Mine does the same thing.
  6. Jul 27, 2019 at 8:57 AM
    Vyprdad
    David
    I took it to the dealer and they said they didn’t see or feel anything abnormal. My truck has 323 miles on it. But it’s like a bind then get past that and everything starts working smooth. So this morning I went under the dash and started looking at the linkage. I can see a linkage piece that is supposed to rotate and move another linkage is actually sliding to the right (towards the gas pedal) then binds close to the mushroomed end of the pin, can’t slide over anymore then starts to rotate as it should. I placed a screwdriver to hold the linkage in place and it started to work smooth like it should. As this price slides to the right to tilts a bit then binds because it can not tilt anymore and is forced to rotate as it should or was designed to. I took pictures to show you the operation of what I am seeing.
    Lunar_Taco23, JAMC[OP] and over60 like this.
  7. Jul 27, 2019 at 10:10 AM
    JAMC
    SW Ontario
    iboards BFmx4
    From your photos it looks like you tried to lube it. Sorry everyone else has the problem but at least I'm not the only one and glad I brought this to everyone's attention.
    wilcam47 and TeecoTaco like this.
  8. Jul 27, 2019 at 10:39 AM
    Vyprdad
    David
    Nope. Didn’t lube it. That was there. Just took pics. One thing else I noticed is the other end of the linkage is doing the same thing on the piece it connects to.
    over60 likes this.
  9. Jul 27, 2019 at 10:41 AM
    Vyprdad
    David
    I am glad I too am not the only one. Thought is was losing my mind lol. Thinking maybe this is the way it supposed to be....
  10. Jul 27, 2019 at 10:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    o_O
    And how did you measure that?
    Don't get me wrong. Rear discs would be nicer to service.
    But drums are not the evil many proclaim them to be.
    JNG, SR-71A and Junkhead like this.
  11. Jul 27, 2019 at 10:48 AM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    You can take a look at mine if you like...I don't have this issue, so you can compare. Then again I don't have push to start either tho, if that linkage is related to that
    shakerhood likes this.
  12. Jul 27, 2019 at 10:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    If the pin will pop out easily, try some washers to fill the space and reduce the movement. Shims as it were.
    Don't make it tight. Add one at a time to see if you can make it work as you like.
    Worst case is you remove them all.
  13. Jul 27, 2019 at 12:19 PM
    hygieneboy
    hygieneboy Well-Known Member
    My 2019 brake pedal feels like that too.
  14. Jul 27, 2019 at 1:03 PM
    JAMC
    SW Ontario
    iboards BFmx4
    Just drove by your house 1/2 hour ago, If I had known I would have stopped in. But it might just be a push button issue.
    TeecoTaco[QUOTED] likes this.
  15. Jul 27, 2019 at 1:07 PM
    JAMC
    SW Ontario
    iboards BFmx4
    Most of us with the issue have new 19's under warranty. Just curious if we all have push button start?
  16. Jul 27, 2019 at 1:15 PM
    TeecoTaco
    SW Ontario
    3 3rd gens at McD's today and another at the lcbo at the same time...none were you lol
  17. Jul 27, 2019 at 1:29 PM
    JAMC
    SW Ontario
    iboards BFmx4
    There's another silver 17 like mine, he's from W island. I saw maybe 2nd gen black one hauling shrubs and bushes to the town dump all morning over by Steinhoff park.
  18. Jul 27, 2019 at 1:30 PM
    TeecoTaco
    SW Ontario
    Yup, was mine, the W island guy and barc red OR at McDs and another barc red at lcbo
  19. Jul 28, 2019 at 3:51 PM
    JAMC
    SW Ontario
    iboards BFmx4
    My roller or cam is clearly over to the right side where you screw driver is, with the grease on the left of the roller toward the arm.
  20. Jul 28, 2019 at 10:22 PM
    Vyprdad
    David
    I have push button start. The part is the cantilever that connects to the upper part that actually pushes in the brake booster rod.
