Brake Pedal Buzz / Vibration When Stopped
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Apr 2, 2016.
  1. Jan 19, 2017 at 5:41 PM
    rhouse181
    rhouse181 Well-Known Member
    2017 TRDOR DCSB
    You can thank that super awesome crawl control feature for your buzzy brake pedal...
    Annoyed me for awhile when I first got my truck too
    Tig3r_Bit likes this.
  2. Jan 19, 2017 at 6:39 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I can't believe that nobody has chimed in with an answer for this yet. I know what it is because it's been that way in 4Runners for a long time. My 04 4Runner does it. Maybe it's a feature that's new to the Tacoma lineup even though it's been in the 4Runners and FJ's (I'm pretty sure) for years?
    It's a brake booster. These trucks don't have normal master cylinders. They have motors attached to them and they build a reserve of pressure so that the truck can apply the brakes on its own either to help you in an emergency stop or to keep one of the wheels from spinning excessively.
    What your feeling is the pump building up pressure because a sensor has detected that the pressure has decreased. That reserve pressure is used any time you brake so the motor will kick on intermittently as you drive to replenish the pressure.
    The only bad part about the system is that it's ridiculously expensive to fix. When it fails it'll cost you about $2500 to replace. Toyota only sells them as complete units. Fortunately they're pretty durable. Most older 4Runners are still on the original unit at 300k miles.
    It's not just for the crawl control. I have a manual transmission so I don't have crawl control but I still have the same brake booster pump.
  3. Jan 19, 2017 at 7:16 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Thank you for that response. I've noticed that the pressure builds upon startup which felt odd to me at first.
    Is it normal to feel a kind of pulse/click/clunk in the pedal under normal braking? Almost the sensation of a single ABS pulse.
    I get this when a moderate braking pressure is applied. If I hit the brake with the same pressure shortly after, I do not feel the sensation. However, I drive for another 10-15 seconds and apply the same moderate pressure and I feel the little pulse again.
    Almost feels like the pedal is slipping on a rubber bump stop but this does not occur when the engine is off.
  4. Jan 19, 2017 at 7:22 PM
    fdbyrne
    Missouri
    I can't say that I'm familiar with that sensation. I'm sorry.
    With mine, both the 4Runner and Tacoma, the brake feels entirely normal except for the occasional high frequency, low amplitude vibration when the pump kicks on.
  5. Jan 24, 2017 at 7:43 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    This is a much better explanation than the dealer saying "that's normal, there is nothing wrong." My 2017 Pro does this light vibrating of the brake pedal randomly. I have yet to figure out a pattern for this behavior, but if it is normal, it gives no reason to worry.
    Tig3r_Bit and fdbyrne[QUOTED] like this.
  6. Sep 17, 2017 at 6:58 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    :facepalm:
  7. Sep 17, 2017 at 7:03 AM
    PF685
    PF685 New Member
    CT
    2017 trd off-road dcsb
    I see this forum is full of useless trolls
    ma2co likes this.
  8. Sep 17, 2017 at 7:34 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Yeah
    Mine does it too. I consider it a "characteristic"
    bubbakingaroo likes this.
  9. Apr 17, 2018 at 9:45 AM
    mcole1987
    mcole1987 Member
    Mark
    Redondo Beach, CA
    2017 Taco TRD OffRoad
    Snugtop Rebel // Vented Windoors // Remote Start
    Thansk for the response! Seems logical.
  10. Apr 26, 2018 at 11:20 AM
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    Brand new 2018 Tacoma Off Road owner right here. I experience this situation too.
  11. Apr 26, 2018 at 1:11 PM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    It's normal. Mine does it.
    bubbakingaroo and Tig3r_Bit like this.
  12. Apr 26, 2018 at 1:18 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    iDrew likes this.
  13. Feb 19, 2019 at 3:57 PM
    bubbakingaroo
    bubbakingaroo Member
    2019 TRD OR 4x4
    Brand new 2019 TRD OR 4x4. Feel slight buzz when first pressing on brake pedal then stops. Only at slow speed. Push again maybe buzz maybe not. Is this just the electric braking system on the ORs? This happens even when in park.
  14. Feb 19, 2019 at 3:58 PM
    bubbakingaroo
    2019 TRD OR 4x4
    slight buzz when pressing on brake pedal at stop (in park) or slow speed>? is this just electric braking system on OR?
  15. Feb 22, 2019 at 5:46 AM
    #35
    Tig3r_Bit
    2018 TRD OR 4x4
    Is normal. My 18 OR does it also. And is only on the OFF-ROAD.
