brake pedal comes up when i start the engine
Discussion in 'New Members' started by lance555, Jan 10, 2011.
  1. Jan 10, 2011 at 5:08 PM
    lance555
    lance555 [OP] New Member
    Maui, Hawaii
    2011 tacoma 4x4 trd offroad
    Hey everybody...i jus got a 2011 tacoma double cab 4x4 trd offroad 6 speed in pyrite mica a few weeks ago and i notice that when i push the brake pedal then start the engine the brake pedal comes up instead of going down a couple inches...is that normal?
    Also when i push the clutch in to shift from first to second the truck makes a thump sound but it shifts smooth through the rest of the gears..do i need to adjust the clutch or something?
    Please help, thank you
  2. Jan 11, 2011 at 4:01 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you have the clutch pedal on the floor while shifting and it's noisy, take it to the dealer.
    Not sure on the brake issue.
  3. Jan 11, 2011 at 4:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I haven't noticed that on my truck..... but I would tend to say it's normal.
    When starting the truck, the system (aka brake booster, etc) is probably being pressurized via vacuum and why the pedal is going upwards. Or, there's a leak somewhere that's allowing the pressure to release when the truck is off (can't replenish pressure while truck is off). That's just a guess.....
    Since you are still under warrantee, take it to a dealer.
  4. Jan 12, 2011 at 12:39 PM
    lance555
    Maui, Hawaii
    Alright...thanks for the info guys
