brake pedal drops slowly under pressure??
Discussion in '1st Gen. Tacomas (1995-2004)' started by micropiper, Jan 8, 2012.
  1. Jan 8, 2012 at 2:47 PM
    micropiper
    micropiper [OP] Admiral of the JOLLY ROGER navy
    damion
    phoenix az
    Four cylinders of pure awesome
    k&n air filter in a modded intake, sliders, new horn, plenty o pinstripes, custom onboard air,cobra cb with custom skidplate,
    1997 4runner 3.6 v6 auto 4wd stock rims and tires with abs. I have replaced the rotors with oem and added a set of duralast creamic based pads with new shoes and drums on the rear. Master cylinder and reservoir are new also. I have visually inspected all the hard lines and checked each wheel for leaks and the level in the reservoir hasnt dropped.
    The entire system has been bled completely a couple of times using new fliud and no air bubbles remain at the wheels. When the engine is off you can pump the pedal 3 times and stand on it and it does not move. With the engine running if you let it sit for a short time and go for the pedal it drops almost to the floor (within an inch or so) then if you push it again it firms up but then slowly drops to toward the floor under pressure. The truck stops very well when you have a chance to pump the brakes first but that first push it feels like theres nothing there. This is my wifes daily driver and I have the same setup on my taco with no issues only diffrence is I have no abs. Please if you have any suggestions let me know!!!!! Im not sure what to do next.
  2. Jan 8, 2012 at 3:49 PM
    Slider 951
    Slider 951 New Member
    Rich
    Orland Park IL.
    '04 4x4 Tacoma
    6 1/2' Western Snowplow Timbrens And Bilsteins
    Check for loose wheel bearings. "Play" in a wheel bearing can allow the rotor ( and hub and wheel) to deflect from its normal rotation. This will push the break pads further back into the caliper than normal. Your first pump makes up this distance and the second gets the job done. (Assuming your calipers are tight) Sometimes wheel bearings can get pretty sloppy without making a lot of noise and a symptom like this can be the first hint that something is wrong. Unfortunately these bearings are a pain to change ( pressed in non adjustable and "sealed") If this is your problem, and you want to "DIY" , do a search, there are several REALLY GOOD write ups.
  3. Jan 8, 2012 at 7:48 PM
    Buggys3sgte
    Buggys3sgte Well-Known Member
    Psycho state of AZ
    97 BUDGET Taco
    Newly rearranged front end, sick Hurst shifter yo gives it lightning fast shifts, thats it more to come.
    Did it do this before you did all the brake work? It possibly could be the brake booster, the diaphram is ripped/leaking.
  4. Jan 9, 2012 at 4:12 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    This is what I was thinking, this or the master cylinder seals are leaking by. If you don't have a leaking wheel cylinder, and your pedal slowly makes its way toward the floor at a stop light, one of those two things are bad.
  5. Jan 9, 2012 at 4:44 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This^^
  6. Jan 9, 2012 at 5:07 AM
    micropiper
    damion
    phoenix az
    The front wheel bearings are less then 6 months old. Yes the pedal has been spongy since i bought the truck. Everything Ive done has made it better but its still not right. Is there a method for testing the booster or the seals in the master?? Thanks for your replies guys!!!!!
  7. Jan 9, 2012 at 5:29 AM
    elykTacos
    elykTacos "Its all ball bearings nowadays"
    Kyle
    Salt Lake City, Utah
    2011, DBLCB , 4x4, Sport, Grey
    Custom sliders, Bilstien 5100s in front - 5100's + AAL + TSB in rear, dif drop, LED's in scoop, CB installed in console, flashlight mount, window tint, locking compartment in bed.
  8. Jan 9, 2012 at 5:08 PM
    micropiper
    damion
    phoenix az
    ok so it ended up to be your abs actuator? I will go and check if the rear shoes are close enough to the drum hat. That is something I had not checked. The master cylinder is less then a month old and is new not refurbished. Is it possible I got a bad one???? Again thanks !!!!!
  9. Jan 10, 2012 at 3:31 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Did you install it ??? If so, did you bleed it properly ? A master cylinder needs to be bench bled before installing, then I usually go around and bleed each wheel to be sure any and all air is out. Boosters rarely go bad, less often than master cylinders anyway. I suppose it is possible you got a bad master cylinder. But I would bleed the hell out of all lines first. I'll have to get back to you on a possible bad booster, I've never experienced one myself, I'm sure there is probably a vacuum check you could do on it, maybe someone else with experience could chime in.
    Edit: Forgot to add... A wheel bearing, brake rotor, etc etc... has nothing to do with a spongy or fading brake pedal, I don't care what anyone says, it's completely and totally unrelated. However, a bad bearing could cause a vibration in the pedal as your are slowing down, and a warped rotor will cause a pulsating pedal which most people have experienced at some time or another. Once you are stopped, and the pedal starts going to the floor, something is leaking by.
  10. Jan 10, 2012 at 3:57 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Ok, got confirmation on the booster... Get a little vacuum hand pump with a gauge if you don't already have one and make sure it's holding vacuum.
    Adjust your rear shoes as mentioned. Make it so they're JUST free enough to allow the drum to spin by hand, even if they're rubbing just a touch that's ok as long as you can spin the drum.
    If your cylinder was properly bled and you're sure there is no other air in the lines, you have a defective master cylinder.
    One other suggestion is use a hand pump to do your bleeding if you're not already. It's the best way to make sure you're getting all the air out.
    I hope this helps you bud !!!
  11. Jan 10, 2012 at 5:27 AM
    micropiper
    damion
    phoenix az
    Yes I installed the master and bled it before according to the instructions included in the box.No air remained in it when reinstalled. I will go get a vacuum gauge and chek the booster for pressure. Thanks everybody TW rules!!!!
  12. Jan 10, 2012 at 5:44 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    If you go to sears, they have a nice little kit that includes the pump and some attachments, you can use it to check vacuum as well as bleed brakes or whatever. Harbor Freight has one for cheaper, but that one didn't last me very long.
  13. Jan 15, 2012 at 6:00 AM
    micropiper
    damion
    phoenix az
    It was the rear brakes not adjusted properly. I jacked up the rear and pulled the e-brake and spun the tires and thet just rolled. Thanks to everybody for the suggestions.
  14. Jan 17, 2012 at 10:53 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    :thumbsup:
  15. Dec 5, 2016 at 6:59 PM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    Hey all!
    Sorry to revive this thread but I've walked into a very similar issue!
    The description of my problem would sound just like the OP.
    I've replaced the front calipers, rear cylinders, pads, shoes, rotors, drums, bled-bled-bled, then had an actual mechanic bleed them again and adjust the rear brake shoes to catch right.
    I still get intermittent spongy brakes where I need to let off and push again to gain brake pressure. not fun when you're pulling a small trailer in NYC!
    (most of these parts were replaced just to do the job right and not come back again and The truck needed new calipers as they were seized)
    Is it likely that the master cylinder needs replacing to gain full strength brakes again?
    Mush Mouse likes this.
  16. Dec 5, 2016 at 7:19 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    if you have a hard pedal when the truck is turned off then the master cylinder is good, if the pedal sinks to the floor with the truck off then its bad
  17. Dec 6, 2016 at 6:27 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    so if my pedal is solid when the truck is off after I give it 2 pumps, but is mushy and shit-tastic when i'm driving....
    but when I think about it, sometimes the pedal just goes soft before I start the truck and I can't really get solid pressure......
    whats your verdict?
  18. Dec 6, 2016 at 10:49 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    Anyone else have a suggestion?
  19. Dec 6, 2016 at 10:56 AM
    Mush Mouse
    mush
    2013 SR5
    with the truck off you should be able to give it some pumps but should harden up, if it sinks to the floor then its bad master cylinder from what I have heard, I had the same issue as you after replacing the front pads, its much better after adjusting the rears, and I think bedding the pads helped also, when I initially replaced the pads it was very noticeable. but I think as another guy stated there is buildup on the rotors that needs to be burned off by proper bedding procedure I didn't do that but after time the brakes have seemed to bedded themselves and are working good now on mine.
  20. Dec 6, 2016 at 11:01 AM
    Mush Mouse
    mush
    2013 SR5
    that kindaof sounds like a Master cylinder I would have it checked out, I took mine to a dealer and asked them to test drive mine and they said the soft pedal is a norm but to adjust the rear and maybe cut the rotors if I wanted better, if it comes to replacing the master cylinder it doesn't look that hard to do yourself but lots people say to use an OEM Toyota master cylinder not an aftermarket one
