Brake pedal goes halfway to floor before it starts working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylanmclean, Jan 25, 2023.
  1. Jan 25, 2023 at 9:23 PM
    Dylanmclean
    Dylanmclean [OP] Active Member
    Dylan
    Red 2005 tacoma
    Hey everyone. I have a 05 taco 4.0 4wd. I have the 4runner bigger brakes on the front. I have had this problem for a long time I just didn't notice it as this is one of my first vehicles until my work got me a work truck and I noticed the brakes were very different and I let a friend try it and he thought that my brakes needed to be bled really bad. The pedal goes about halfway to the floor before the brakes start to work. But when the truck is off the brakes pump up just fine and there is no free play. I replaced the master cylinder today and gave it a good bleed thinking that would work but it still has the same problem. I then went to the local gravel parking lot and actuated the abs a few times and gave it a good bleed and it still has the problem. there is no leaks anywhere, the rear brakes are in adjustment, I replaced the wheel cylinders recently. I saw there are other threads on this but I could not find a good answer. Could this be a problem in the booster?
  2. Jan 25, 2023 at 9:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try line-locking the rear brakes and see if the pedal gets better or changes
  3. Jan 26, 2023 at 8:08 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    are the rear drums actually adjusted properly?
    b_r_o likes this.
  4. Jan 26, 2023 at 10:35 AM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    I will try that
  5. Jan 26, 2023 at 10:36 AM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    Yes they are properly adjusted I also manually made sure using the adjuster before I made the post.
  6. Jan 26, 2023 at 10:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you using 4th gen 4Runner Sport 13WH calipers or 5th gen 4Runner 14WA calipers? The 14WA calipers have bigger pistons, so they require more fluid flow (i.e. more pedal travel). Test drive a 2010+ 4Runner if you have an opportunity and see if it's just as bad. I know the pedal feel on my 4Runner is garbage. :laugh:
  7. Jan 26, 2023 at 10:46 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    Adjust rear drums. It might take multiple attempts if the star wheels are dirty/stuck.
