brake pedal goes to the floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by golstho, Apr 24, 2012.
  1. Apr 24, 2012 at 2:51 PM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    2006 double cab 4x4 brakes dont grip very well and pedal travels all the way to the floor. i have installed all new pads and shoes, bled all the lines and the master cylinder. pedal still goes all the way to the floor and truck wont stop. sometimes when you stomp on the pedal hard the brakes will grab hard and then the pedal moves under your foot and the breaks quit grabbing, but its not the abs doing it so i dont know what do do next.
    buy a master cylinder or a break booster?
    anyone had this problem before?
  2. Apr 24, 2012 at 2:54 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    ABS fucked up... maybe? :notsure:
  3. Apr 24, 2012 at 3:01 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Kinda sounds like the master cylinder is leaking internally back to the res., maybe a bad seal inside? A bad booster would make it harder to push the pedal if you got pressure, but it sounds like you are not making any pressure from the master. Good luck.
  4. Apr 24, 2012 at 6:03 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you adjusted the rear shoes properly, and bled the system correctly, most likely you need a M/C. Also check that the pedal and pushrod linkage return all the way. A failed vacuum booster will give a hard pedal with little braking power, not your symptoms.
  5. Apr 24, 2012 at 6:10 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    According to my Chiltons, if air gets into the master cylinder, it must've bled by the dealer using a special service tool.
    ABS master cylinder replacement not a DIY job according to them.
    Go to ncttora and look up the FSM for master cylinder brake bleeding.
  6. Apr 24, 2012 at 6:25 PM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    guess i need to get a master cylinder. found one for $125.
  7. May 30, 2012 at 5:56 AM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    finally got the new master cylinder on and still have the problem. pedal goes all the way to the floor, but it does feel like the brakes are grabbing a little harder. i also noticed when bleading the right rear i got a lot of air. wonder if this could be a wheel cylinder problem?
  8. May 30, 2012 at 7:11 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    you still have air in the system.
    when you took out the old MC was there brake fluid anywhere it shouldnt be? like coming out of the pushrod seals?
  9. May 30, 2012 at 7:17 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Definitely air in the lines.
    What is your procedure for bleeding the brakes? Best bet is to have a buddy work the pedal while you open/close the bleeder valves at each wheel, starting with the furthest from the master cylinder and working your way around to the closest.
    Make sure the fluid level never gets too low in the reservoir while you're doing this or you'll have to start all over at the rear passenger side.
  10. May 30, 2012 at 7:22 AM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    i did not notice any leaking fluid but i was kinda in a hurry.
  11. May 30, 2012 at 7:23 AM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    how does this affect the brakes?
  12. May 30, 2012 at 7:25 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
  13. May 30, 2012 at 7:27 AM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    i started with the rr,lf,rf,lf. i first tried to pull o vacume on each but kept getting air so then go my wife to do the pump and hold method. i got a tone of air out of the rear brake lines more than i have ever seen and not 100% sure i got it all. where could i be getting all this air fom? is it possible i have a bad flexable line?
  14. May 30, 2012 at 8:03 AM
    mjp2
    NJ
    Should be rear passenger, rear driver, front passenger, front driver. Don't move on until there is zero air coming out at the wheel you're working on, and always keep an eye on the reservoir to make sure it never drops below half full.
    Have your wife start pressing on the pedal and then open the valve. Close it before she gets the pedal to the floor and make sure she does not lift the pedal until the valve is closed or you'll suck more air into the system. It's a 5 minute conversation consisting of:
    You: "Down."
    Her: "Down."
    You: "Up."
    Her: "Up."
    Boring but effective.
  15. May 30, 2012 at 8:16 AM
    aficianado
    back to bone stock.
    exactly!!
    but with my wife it is more like:
    me: you down?
    her: yes...i'm down....now.
    Me: fuck! down honey...
    her:eek:k..down!!
    me: i'm opening it up
    her: up!
    me: not yet!
    her: you said UP.
    me: i said, i am opening it UP!
    her: Up!
    me:fuck fuck fuck
    her: try doing yourself! amongst other things!!..
    me: hello, neighbor: you busy?
    gkomo likes this.
  16. May 30, 2012 at 8:17 AM
    aficianado
    back to bone stock.
    motive power bleeder saved my marriage.
  17. May 30, 2012 at 8:19 AM
    mjp2
    NJ
    :laughing:
    I've seen those advertised but have never seen how they work.
    So, how do they work? I imagine it's a snug fitting over the reservoir that pressurizes the system?
  18. May 30, 2012 at 8:25 AM
    DrewH
    DrewH Well-Known Member
    It doesn't... hes being a douche.
  19. May 30, 2012 at 8:29 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Exactly how my husband and I do it.
    To the OP: Make sure your wife has constant pressure on that pedal while in the DOWN position. DO NOT open the bleeder until after she says DOWN. Then.....when you open the bleeder valve, that pedal will move down to the floor (make sure she understands to apply constant pressure to the pedal even after it 'stops' the first time. After you open the bleeder, the pedal will go down to the floor as it should). Then, when you're done...close the valve and tell her UP.
    Did you BENCH bleed the Master cylinder?
    When the truck is parked - put your foot on the brake as hard as you can for 10 seconds (or more). Does the pedal come to a stop? Or does it keep moving slightly towards the floor? If it's moving.....then you've got a leak somewhere.
  20. May 30, 2012 at 9:05 AM
    golstho
    golstho [OP] Member
    Alabama
    06 Tacoma
    i did not bench bleed the master cylinder in a vise and tilt it back and forth as some instructions i have read. i just put it on the truck and followed the instructions from toyota that state to put your fingers over the ports and bleed.
    when truck is off if you press the pedal it will go all the way to the floor well before 10 seconds are up, but i cant find a leak anywhere...
