Brake pedal goes to the floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rdavis78, Apr 27, 2024.
  1. Apr 27, 2024 at 2:16 PM
    Rdavis78
    Rdavis78 [OP] Active Member
    Robert
    Need help here please
    I have a 2009 Tacoma 4x4
    The pedal goes to the floor
    Here is what's new
    Master cylinder, pads , calipers wheel cylinder both bach wheels, and shoes
    I have bleed the the system about ten times and no air is in the lines what else can it be
  2. Apr 27, 2024 at 2:17 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Are the rear drums adjusted properly? Are you losing fluid when you hit the pedal?
    Kwikvette likes this.
  3. Apr 27, 2024 at 2:19 PM
    Rdavis78
    Robert
    No leaks of any kind I'm thinking it might be the brake booster
  4. Apr 27, 2024 at 2:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Some people ignore bleeding the lspv only to realize later it had air.
    wilcam47 likes this.
  5. Apr 27, 2024 at 2:21 PM
    Rdavis78
    Robert
    I did do a abs bleed to
    inwood customs likes this.
  6. Apr 27, 2024 at 2:24 PM
    Rdavis78
    Robert
    Where is the lspv at this my first Toyota
  7. Apr 27, 2024 at 2:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have the calipers on the correct sides (bleeders to the top)?:anonymous:
    wilcam47 and winkel like this.
  8. Apr 27, 2024 at 2:28 PM
    Rdavis78
    Robert
    Yeah
    Dm93 likes this.
  9. Apr 27, 2024 at 3:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Just checking lol, I've had several come into the shop with the bleeders on the bottom.
    If you have verified there's no air in anything you may have an ABS module failing.
    You have the vacuum booster and not the hydraulic booster correct?
  10. Apr 27, 2024 at 4:03 PM
    Rdavis78
    Robert
    Yeah it's a vacuum booster when I got the truck I replaced all the brakes front and rear and had a soft pedal then
    But when I push the brake pedal in the truck I hear air like sound
  11. Apr 27, 2024 at 4:44 PM
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    Did you bench bleed the Master before you installed it?
    Booster won't matter as far as no brake pedal goes.
    MR5X5 and Dm93 like this.
  12. Apr 27, 2024 at 4:53 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Do you have the star adjusters on the back drums adjusted out to where the shoes are just dragging in the drums a little? If not, you're displacing a lot of fluid when you push the brakes.
    If you keep pumping, does the pedal eventually pump up and have some resistance?
    Kolter45 likes this.
  13. Apr 27, 2024 at 4:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    With the truck off do the brakes pump up?
    b_r_o likes this.
  14. Apr 27, 2024 at 5:10 PM
    Rdavis78
    Robert
    Yes I bench bleed the master cylinder
  15. Apr 27, 2024 at 5:13 PM
    Rdavis78
    Robert
    Yeah I have the star adjustment on the back and it's drags just a little bit
  16. Apr 27, 2024 at 5:14 PM
    Rdavis78
    Robert
    With the truck turned off the pedal pumps up good in three or four pumps
  17. Apr 27, 2024 at 5:19 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    You have air in the lines or a line leaking somewhere.
    Jack of up the truck and take the wheels off.
    Have someone slowly and gently pump the brakes, look for leaks at the brake line attachment points, the parts where they bolt to the frame, etc.
    If you have a manual transmission make sure you don't have any leaks there.
    I'm willing to bet you still have aire in the lines...it can take you a lot more pumps than you realize to get all the air out of the system.
    Even with air in the line you should be able to pump enough times to eventually get some resistance.
    TheWildMan likes this.
  18. Apr 27, 2024 at 5:20 PM
    kidthatsirish
    You have air in the lines then.
  19. Apr 27, 2024 at 5:44 PM
    Rdavis78
    Robert
    Thank you I try it again tomorrow and check if theirs any I find I'll let y'all know
  20. Apr 28, 2024 at 9:42 AM
    Rdavis78
    Robert
    No leaks in brake lines at all
