Brake pedal goes to the floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rdavis78, Apr 27, 2024.
  1. Apr 28, 2024 at 9:50 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    When you adjusted the rear drums, did you cycle the hand brake a few times then rechecked the adjustment?
    other suggestions would be to keep bleeding, and if you don't live near anyone and the truck can stop would be to go around 30mph and lock the brakes a few times to cycle the abs pump which may help purge any air. Otherwise keep bleeding
  2. Apr 28, 2024 at 10:15 AM
    Rdavis78
    Rdavis78 [OP] Active Member
    Robert
    I did ABS bleed and still a soft pedal I'm about to set it on fire or sale that's where I'm at
  3. Apr 28, 2024 at 10:17 AM
    Waasheem
    Waasheem
    2007 xrunner
    Think of your brakes hydraulics as a sealed system. Master cylinder, abs module, disc calipers, drum wheel cylinders. If any of this is opened, air gets in. Once that happens, the air seems to want to get stuck in the abs module. Once that happens traditional bleeding isn't gonna get it out.
    Now you have 2 options. Well, really 3. Take it to a dealership or shop with the correct techstream software to cycle the abs modules and get the air out. Or as suggested above, slam the brakes on a low traction surface to activate the abs, bleed, repeat until good. Or drive with limited braking capability until you crash, really not an option in my opinion. A forth option would be to buy the tool to cycle the abs module. Theres only one I've heard that works but it excludes certain years. Not really a good option because you're buying a unitasker tool thats a bit expensive. Theres plenty of scanners that claim to have the capability but as many have found out, they don't. Even the super expensive snapon ones won't.
    So your best plan would be to find a dirt or gravel patch, lock up the brakes to activate the abs. Go home and bleed the system. Repeat as needed.
    winkel likes this.
  4. Apr 28, 2024 at 10:22 AM
    Rdavis78
    Robert
    Ok I'll try that
    Ok update I did do the the abs did turn on went and bleed the brakes and did 3 more times still soft pedal
  5. Apr 28, 2024 at 10:41 AM
    Rdavis78
    Robert
    With the truck running I can pump the brakes 3 or 4 times and it will start to get stiffer
  6. Apr 28, 2024 at 1:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Then do this:
    Kolter45 and winkel like this.
  7. Apr 28, 2024 at 2:23 PM
    Rdavis78
    Robert
    I have done all of that but I hear air coming from the brake pedal area when I push the brake pedal in the truck
  8. Apr 28, 2024 at 2:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    How? With TechStream?
  9. Apr 28, 2024 at 2:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Common Signs of a Bad Brake Booster
    If your brake booster is failing or it’s no longer functioning, it can affect your braking system as well as other systems. Signs can include:
    • The brake pedal is harder to push than normal. Since the brake booster operates with vacuum, the degree to which the brakes are more difficult to apply can vary. Often, the first application can be almost normal while subsequent applications shortly after get progressively harder.
    • It takes longer to stop your car. Since your braking power doesn’t have the necessary assistance from the booster, your stopping distance can increase.
    • Engine stumbling or stalling. If there’s a massive vacuum leak in the booster, it could draw more boost than normal when you apply the brakes. It takes vacuum away from other components, and it can cause your engine to stumble, the RPMs to drop, and your engine could stall.
    • The Check Engine Light can come on. Some cars are equipped with a brake booster vacuum sensor. If you have a leak, it can trigger the Check Engine light to come on.
    • Whistling sounds. A vacuum leak at the booster can translate into a whistling or hissing sound, and it’s often worst when applying the brakes.
    https://www.google.com/search?chann...=Symptoms+of+a+defective+Vacuum+brake+booster
    mikkydee and Micbt25 like this.
  10. Apr 28, 2024 at 5:20 PM
    Rdavis78
    Robert
    Not with techstream a different scan tool
  11. Apr 28, 2024 at 5:21 PM
    Rdavis78
    Robert
    I'm going to buy a brake booster even when the brake pedal is easy to push
  12. Apr 30, 2024 at 1:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Okay, Let us know how it turns out please...
    Thanks
  13. Apr 30, 2024 at 3:29 PM
    Rdavis78
    Robert
    Ok I will
  14. May 5, 2024 at 4:20 PM
    Rdavis78
    Robert
    I put a new brake booster on and new rubber brake lines on the front and bleed all the brake lines and the ABS and that helped a lot
    winkel likes this.
  15. May 5, 2024 at 4:54 PM
    #35
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Have you actually power bled the system starting at the furthest wheel or are you hand bleeding?
  16. May 5, 2024 at 7:57 PM
    #36
    Rdavis78
    Robert
    I hand bled I'm going to take it to the shop and let them do the power bled
  17. May 5, 2024 at 9:43 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does the parking brake work good when you pull the handle?
    winkel likes this.
  18. May 6, 2024 at 2:34 AM
    #38
    Rdavis78
    Robert
  19. May 8, 2024 at 8:53 AM
    #39
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    How did u bleed the ABS?
  20. May 8, 2024 at 5:02 PM
    #40
    Rdavis78
    Robert
    Scan tool
    From matco
