Brake Pedal is loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fallen, Jun 10, 2024.
  1. Jun 10, 2024 at 8:30 PM
    Fallen
    Fallen [OP] New Member
    Brian
    2007 Toyota Tacoma TRD
    Stock
    So I’ve been looking around the internet for any solutions for my 2007 Toyota tacoma having a loose pedal which doesn’t let my truck brake good, I tried getting rid of any air in brake fluid and it didn't work, I bled my brakes and it didnt work, changed the master cylinder and it didnt work, changed brake pads, did not work, and I keep looking online and there really isnt that much left to do besides getting a new truck which is something I really hope I don't have to do since I love my truck. Is there anything else I can do?
  2. Jun 10, 2024 at 8:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Taking the truck to qualified shop would be much cheaper than a new truck.
    Personally, I' d make sure the system is bled correctly. To do so requires a scan tool.
    Just pay a shop. Don't buy anymore parts. It will be cheaper.
    2009Access4x4 and wilcam47 like this.
  3. Jun 10, 2024 at 8:35 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Was it always like this or is it new symptom? Only thing i can think of is the rod between brake booster and master cylinder need adjusted or is bent
  4. Jun 10, 2024 at 8:41 PM
    Fallen
    Brian
    Stock
    You’re probably right, my brain is too underdeveloped for this thanks though
  5. Jun 10, 2024 at 8:47 PM
    Fallen
    Brian
    Stock
    this is a new symptom it never occurred until last week,
    wilcam47[QUOTED] likes this.
  6. Jun 10, 2024 at 9:09 PM
    TnShooter
    Deogee
    STOCK
    No offense intended.
    Wasn't saying it as an insult.
    Even I break down a pay people sometimes.
    What else are you to do if you've tried everything, and have no other ideas?
    Me? I take it to someone that knows what to do.
    I make my problem, their problem. And they also get to "do it again" if it isn't fixed.
    Again. Based on your description, I'd be looking at bleeding the brakes.
    I wasn't kidding when I said you need a scan tool. You 100% need it if you have a Vacuum assist system.
    Best of luck to you.
    ColoradoTJ and 2009Access4x4 like this.
  7. Jun 10, 2024 at 9:11 PM
    Fallen
    Brian
    Stock
    Dont worry I know you didnt mean any offense
    TnShooter[QUOTED] likes this.
  8. Jun 10, 2024 at 10:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What do you mean loose? Is the pedal arm loose up at the hinge?
    2009Access4x4 likes this.
