Brake pedal sinks under steady pressure.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MacMedic, Feb 21, 2019.
  1. Feb 21, 2019 at 10:07 AM
    MacMedic
    MacMedic [OP] Well-Known Member
    2016 Black Tacoma TRD Sport
    If I step on my brake pedal (2016 Sport Access Cab) it sinks slowly to the floor. I have a good pedal when I step on them ... but if I hold the pedal, say at a stop sign... it sinks.
    I have replaced the rotors shoes and brake hoses... bled the system.... but still I have a sinking pedal.
    I would think it was a booster as I have a firm solid pedal when the truck is off.
    Toyota says.... (wait for it...) They all do that...
    Anyone else have this happen??
  2. Feb 21, 2019 at 10:10 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Sounds like a brake system leak to me. Have you checked your hoses, lines, bleeders and calipers to make sure they're not leaking. A bad booster won't result in the pedal sinking (I had a bad booster on my 2000 XJ). The only way the pedal will sink is a lack of pressure in the system, meaning you're adding pressure with the pedal and it's escaping somewhere.
  3. Feb 21, 2019 at 10:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Master cylinder is suspect.
    Inferno!, Shellshock, TimC and 6 others like this.
  4. Feb 21, 2019 at 10:18 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds like an internal MC leak.
    r1200gs4ok and Boghog1 like this.
  5. Feb 21, 2019 at 10:22 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I agree. I thought that since the new ones are getting a master cylinder recall and this sounds like a master cylinder symptom, its very possible.
    Also its very easy to see if "they all do that." Pick a random truck on the sales lot and ask for them to start it for you. You dont even have to leave the parking spot, you just want to sit there with your foot on the brake...
    Donjuan likes this.
  6. Feb 21, 2019 at 11:31 AM
    Wucat
    Wucat Active Member
    Wu
    Ky
    2018 TRD Sport
    Same experience with 2018 Sport (under warranty) equipped with the vacuum brake booster. Took it to two dealerships while explaining a sealed system containing a non-compressible fluid should show no settling of the pedal unless there was a leak. "They all do that".
    No, they don't.
    Third dealership, I pointed out a trace of brake fluid trickling down the booster drum. They contacted corporate, gave me a loaner on the spot & replaced the MC.
  7. Feb 21, 2019 at 2:07 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i would go back to the other two dealers and have a nice but firm conversation
    TimC likes this.
  8. Feb 21, 2019 at 3:05 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    No fluid leak? Bad mc. No way it's okay. Safety issue if you are sitting behind someone holding the pedal steady and it stays releasing.
  9. Feb 21, 2019 at 3:31 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yeah... you should be able to depress it several times before it firms up
    You bled the master cylinder, brake lines and brake actuator?
  10. Feb 21, 2019 at 3:47 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    When you bled the brakes, did you place something under the brake pedal to keep from fully depressing it?
    You never want to press the brake pedal to the floor, as you can damage the seals in the master cylinder by over extending the cylinder.
  11. Feb 21, 2019 at 7:29 PM
    MacMedic
    all bled fine.. and is a firm pedal with no leak down with no engine running..
    I think at an idle there's not enough vacuum...
    I may plug the master cylinder and see if the pedal drops..
    no leaks anywhere ....
  12. Feb 22, 2019 at 3:31 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I read this thread yesterday and today I paid closer attention to mine. At a stop light if I put a little more force once stopped the pedal will go down more. It won't sink if I keep the same pressure. When I pulled in my driveway I checked it again and the same way. When I shut the engine off I then released the pedal and pressed it again, and no sinking. With my foot on the brake holding the same pressure, I started it up and the sinking feeling was there, however, once released and pressed as long as I keep the same pressure it will not sink, I have to put more weight/pressure to get it to sink. I have a 2018 Sport double cab and I have had the Master Cyl replaced under the recall.
