Brake pedal slowly sinks to floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KIMZJOI, Jul 6, 2018.
  1. Jul 6, 2018 at 10:02 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    Hi ya'all
    I need some help!!
    We have a 2011 Toyota Tacoma and the brake pedal will continue to go to the floor after you stop.
    We have change the brake pads, master cylinder, flushed the lines, checked the fuses to the ABS - nothing seems to help.
    The dealer service rep told me that it is "normal" for these Tacoma's and even the new Tundra's to do this as they all have an "electronic braking system".
    Have any of you experienced this?? And if so, what have you done to make it stop?
    I appreciate any and all help -we are stumped right now and don't know what to do.
    Thank you,
    Kimzjoi
  2. Jul 6, 2018 at 10:03 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Bullshit, when im at a redlight waiting, my brake pedal does NOT keep dropping till it hits the floor
    wilcam47, Jeffch and Tnronin like this.
  3. Jul 6, 2018 at 10:06 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    I am sorry - but ours is doing this - we have it at a mechanics shop and it is doing it to him as well.....I am just asking for help / advice...
  4. Jul 6, 2018 at 10:08 AM
    inwood customs
    Dave
    Sorry, I wasnt arguing with you... i was calling bs on the service writer who told u it was normal.
    wilcam47, outlawtacoma and Jeffch like this.
  5. Jul 6, 2018 at 10:09 AM
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    Is there a master cylinder or some other hydraulic cylinder similar to a clutch?
  6. Jul 6, 2018 at 10:12 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    Thank you Inwood Customs - I wasn't sure lol
    inwood customs likes this.
  7. Jul 6, 2018 at 10:14 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    It is a master cylinder
  8. Jul 6, 2018 at 10:15 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    X2 Master Cylinder
  9. Jul 6, 2018 at 10:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    A master change and line flushes are very difficult to be successful with if you don't have Techstream to properly cycle the ABS system in the process.
    I don't know what order your parts were changed in, but I'd start on the path to correction with a proper bleeding.
    And no, the pedal should not sink to the floor. The chuckehead who told you that should be reported. It's dangerous.
    Keep in mind. Some service writers are former techs who have some savvy and give reasonable thoughts. Ones who are smart, but don't know answers don't make stuff up, they let the techs solve the problem.
    Ones who are not tech savvy, other than a few terms, but like selling services, well, they can be chuckleheads.
  10. Jul 6, 2018 at 10:20 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    We have replaced the wheel cylinders, rotors, brake pads, master cylinder, all new fluid in the brake line, and adjusted the pedal....we checked the fuses too.....all of this in the last two weeks....so needless to say we are stumped as to why it is still slipping
  11. Jul 6, 2018 at 10:20 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    There are brake cylinders within the interior of the rear brake drums > if they leak or weep fluid out of them... If they are damaged... this will cause the exact problem you are describing.
    A new Master cylinder is all fine and good but check to see if you are losing brake fluid...
    wilcam47 likes this.
  12. Jul 6, 2018 at 10:22 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    Clearwater - he did say I could bring it in for a tech to look at it for $95.00.....
  13. Jul 6, 2018 at 10:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    IF there are no leaks / fluid loss........... pretty simple really
    Your new master is bad (reman?) or the system is not properly bled.
    MurderedTacoV2 and Skyway like this.
  14. Jul 6, 2018 at 10:29 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    You put in a whole new master cylinder already and its still doing that? IIRC a cause of this could be worn/leaking seals on the interior of the master cylinder. The push rod for the master cylinder is okay im assuming, got me stumped. Was the new master cylinder OEM new or some sort of rebuild?
  15. Jul 6, 2018 at 10:30 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    My thoughts exactly.
  16. Jul 6, 2018 at 10:31 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    +1 for bleeding the brakes. I did that to mine when I first got it, because the pedal would hit the floor and it would still roll at bit!! Never assume someone did it right the last time. After bleeding was alot better, but still got new pads and calipers.
    There is a part of me that thinks the shop is taking OP for a ride. Thats alot of brake work.
  17. Jul 6, 2018 at 10:31 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  18. Jul 6, 2018 at 10:34 AM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    you guys are awesome!!
    Thank you for responding so quickly - I will go to the mechanics when I take lunch and let him know your ideas :)
  19. Jul 6, 2018 at 10:34 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    also, he bench bled the new master cylinder before putting it into the truck right? Correctly, without overextending it. I would hope so!
  20. Jul 6, 2018 at 11:20 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Was the master cylinder new from Toyota, aftermarket or rebuilt? We have seen MANY problems with the aftermarket and rebuilt units.
    Sometimes an ABS event (meaning you find some gravel or dirt and stop hard enough for the ABS to activate) can clear up your issues, there may be some debris in the ABS hydraulic unit causing your problem. Although not as common on Toyota, GM has had many issues with failed ABS hydraulic units failing and causing the "pedal falling" symptom.
