Brake pedal slowly sinks to floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KIMZJOI, Jul 6, 2018.
  1. Jul 6, 2018 at 12:57 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Are you a manual or auto trans?
    My 08 2.7 uses the same master and resivor for both brakes and clutch.
    Unsure if it has anything to do with your issue but I do as much of my own wrenching as possible and the 2 using the same stuff may be a maybe.
    Skyway likes this.
  2. Jul 10, 2018 at 5:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    We are waiting to hear the solution.........
    KIMZJOI[OP], slomoe and Skyway like this.
  3. Jul 13, 2018 at 2:33 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
  4. Jul 13, 2018 at 2:39 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Master Cylinder is leaking, this is a test they taught us back in school. If the pedal slowly keeps going down, the MC is going out. Get that thing replaced ASAP before you fly into a wall at 60 mph
    KIMZJOI[OP] and MurderedTacoV2 like this.
  5. Jul 13, 2018 at 6:19 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Spit balling here but I had a similar situation on my old Toyota pickup when I blew a rear brake line.
    It might be a proportioning valve problem. After I had the line replaced, my pedal was doing the same thing and it was not losing any fluid. I heard and tried....stomp the brake pedal several times, real fast. You don't have to be moving when you do this. Just stomp it several times really fast and maybe it will allow the valve to shift back to where it belongs. I know it sounds crazy but mine was fine after doing this a couple of times.
    KIMZJOI[OP] likes this.
  6. Jul 13, 2018 at 8:03 PM
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    Totally thread jacking while we wait for a solution but I’ve seen you in all the brake threads, Bill.
    I did some SS lines and bleed today. I never once got pure fluid out of the bleeder valves it was always bubbly. After about 16 oz of fluid I Decided my method was dead wrong and went to take it to a mechanic. So I slowly back out.. check the brakes. Best The truck has ever felt.
    What’s going on here?
    I was using a harbor freight vac bleeder btw.
  7. Jul 14, 2018 at 4:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Nah. Not really. I've just done enough of my own that I have a bit of experience to offer.
    I can't really say. I've never used a vac bleeder of any kind. I know they are all the rage, but I've always been successful with 2 person pedal pumping. Or on a car I did a lot more fluid changes, using speed bleeders.
    It's always good to include your year truck and such in your profile, or in your post, when asking for tips. It might matter in getting the best answers.
    Did you bleed the whole system? And if yes, starting at the furthest point? Any chance the ABS got drained some? As in will the truck stop well with a good pedal, but the pedal fall at idle, under pressure, as if the master were bad?
  8. Jul 14, 2018 at 6:13 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Remember with the vacuum bleeder when you loosen the bleeder screw it can/will pull air bubbles from the threads around the outside of the bleeder screw. So you might actually have all the air out of the system hence the better then ever feel.
    Slamuel[QUOTED] likes this.
  9. Jul 14, 2018 at 7:00 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    That has been my experience with vacuum bleeders. But, I've always got a good bleed with them.
  10. Jul 15, 2018 at 2:34 PM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    It is a 2011 Toyota Tacoma
    2 wheel drive
    Automatic
    And has a little over 76000 Miles on it
    My son just texted today to say the brakes were slipping AGAIN
    Aarrrggghhhhh
  11. Jul 15, 2018 at 2:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    Ok. No fluid loss?
    I'm going with air in the ABS system.
    Likely to require someone with a Techstream device to successfully bleed.
  12. Jul 15, 2018 at 3:12 PM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    Hi Clearwater
    No fluid loss that we could see
    We have replaced pretty much everything now
    Had all the fluid flushed and replaced
    It worked for a week and then we got the text today that it isn’t
    Making arrangements to get it back from our son to start working on it again
    We will check about the air in the ABS
  13. Jul 15, 2018 at 3:22 PM
    ModestMods
    ModestMods Well-Known Member
    Jax, Fl.
    2012 DCLB 4x4
    Suspension. Billy 5100's all four corners. Fronts set at 0 with Eibach 620 coils for level. Tp14 spacer driver side. Wheels. 17" ultra mavericks with 265/70/17 nitto terra grappler g2. Exterior. super white grill. Debaged. Black housing headlights. Black Led third brake light. Black Depo Tail lights Interior. Led interior bulbs. Neoprene seat covers
  14. Jul 15, 2018 at 3:56 PM
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    ModestMods
    That’s how I feel too lol
    Skyway and ModestMods like this.
  15. Jul 27, 2018 at 12:34 PM
    #35
    KIMZJOI
    KIMZJOI [OP] Member
    Kimberly
    2011 Toyota Tacoma
    Okay so the problem continues
    The brakes are grabbing so bad when you go forward
    We went in reverse and at first it seemed to unlock it but now that isn’t working
    It sounds horrible
    Edit:
    Possible fix: the mechanic didn’t tighten the caliper bolt
  16. Jul 28, 2018 at 12:05 AM
    #36
    Jason J
    oregon
    08 tacoma 4x4
    Pull the rear drums off look for any fluid on brake shoes.
  17. Sep 21, 2018 at 6:21 AM
    #37
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Hey @KIMZJOI, did you ever figure out what the issue was?
  18. Sep 21, 2018 at 3:14 PM
    #38
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    This may seem silly, but the bleeder valve is at the TOP of the caliper and the feed line is in the midpoint right? Could the calipers be mounted upside down on the wrong sides of the truck? That would trap air in the caliper that would never come out no matter how much bleeding you did...
    (Just read the entire thread because I just did my brakes and hate the spongy travel on the pressing of the 2nd gen brakes)
  19. Sep 21, 2018 at 3:35 PM
    #39
    67siia
    67siia Well-Known Member
    J
    32164
    2009 4WD DCLB aka Chupacabra
    No flipping way that is normal... as many suggested master cylinder
  20. Sep 22, 2018 at 3:35 PM
    #40
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I would approach this by replacing all four stock bleeders with speed bleeders. Bleed each one after install then take the truck to a sand/gravel road and stomp on the brakes a few times to activate the ABS system. Return to shop and bleed each corner again. parts are: rear = sb1010, front = sb7100.
