Brake pedal still "spongy" after changing MC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedNeckMetalHead_333, Dec 12, 2015.
  1. Dec 12, 2015 at 1:04 AM
    RedNeckMetalHead_333 [OP] New Member
    2010 Tacoma access cab
    My dad and I changed the master cylinder on my Tacoma because the brake pedal was "spongy," and wasnt holding pressure. We bled the brakes 3 different times but the pedal is still "spongy" and still not holding pressure. Is this a sequencing problem or is it more serious? We bled from driver front and made a circle. This was our first time changing a master cylinder
  2. Dec 12, 2015 at 2:29 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    sounds like you still have air in there somewhere, keep at it. good luck:thumbsup:
  3. Dec 12, 2015 at 3:14 AM
    spinglow
    spinglow Well-Known Member
    cory
    Oregon
    2015 tacoma dcsb trd off road
    Did you bench bled the new master cylinder if not Google it and watch a YouTube vid!!!!
    Lester Lugnut likes this.
  4. Dec 12, 2015 at 3:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Even a hairline leak somewhere in the system could cause spongy pedal.
    Try this.... Get underneath the truck and look at all the braking components, including brake lines, etc. Take notice to anything 'wet' or potential signs of leaks. With truck in park and running. Step on the brake pedal AS HARD AS YOU CAN and keep your foot there holding pressure on it.
    In a completely closed system, the pedal shouldn't move at all once you've reached full downward position. If the pedal moves even slightly downward while you're holding your foot on it....you have a leak. After doing this 'test' - crawl underneath the truck again and look for signs that new fluid has come out. Don't forget to inspect your rear wheel cylinders too.
    spinglow likes this.
  5. Dec 12, 2015 at 4:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Always start at the wheel furthest from the master cylinder and work towards the master cylinder...
    This makes it easy:
    http://www.motiveproducts.com/
    Chris(NJ) likes this.
  6. Dec 12, 2015 at 4:44 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    ^This.
    Although I doubt it made much difference if this is a constant problem that you're experiencing. I always thought the Tacoma had a weak brake pedal to begin with.
    What do you mean when you say it wont hold pressure? Will the pedal eventually hit the floor? Or just that it doesnt grab very well w/ light pressure? Are you losing fluid out of the reservoir? That'd be a pretty big indicator of a much more serious problem.
    I put Stainless brake lines on the truck and it did help a little bit w/ pedal feel imo.
  7. Dec 12, 2015 at 8:35 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Also, check the adjustment of the rear shoes and the front wheel bearings for play if the pedal feel is the same as before the new master cylinder. It may well be a mechanical issue, not a hydraulic issue causing your soft pedal.
    Blkvoodoo likes this.
  8. Dec 12, 2015 at 9:52 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2 - don't know if that is you problem - probably not but I always start at right rear - left rear - right front - left front. You can DIY with the motive - nobody pushing the peddle.
  9. Dec 12, 2015 at 10:10 AM
    george3
    New Jersey
    How does a woman become a expert mechanic and a paint ball champion ??
    I must rethink my blatant sexism.
    Janster[QUOTED] likes this.
  10. Dec 13, 2015 at 6:14 AM
    Janster
    Jandy
    Lancaster, PA
    Bahahahahaaa....that's funny. OMG...I think I woke up on the wrong side of the gene pool and have been hopelessly lost in the tomboy sector.
    Actually...I had an issue with our Jeep after upgrading the Master cylinder and by accident, I took notice that the pedal wouldn't stay still and the 'light bulb' went off that I was probably losing fluid somewhere.
    Never played paintball....but used to play airsoft. And then...my husband and I realized we were too old and couldn't keep up with teeny boppers & young kids running around in the woods. Haven't played in probably 5 years. I can mark it off 'the list' LOL
  11. Dec 13, 2015 at 7:36 AM
    george3
    New Jersey
    Glad U took it as intended. I'm getting a little senile so 5 years made airsoft into paintball. You and yours enjoy Christmas.
