brake pedal to floor... Wheel bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoman James, Jul 11, 2017.
  1. Jul 11, 2017 at 11:20 PM
    Tacoman James
    Tacoman James [OP] I am Tacoman
    James
    Maine
    2013 Tacoma SR5 access cab 4x4
    3" lift front Bilstien 5100s at 0 with OME 887 coils, Freedom Offroad UCAs, Bilstien 5100 rear shocks, 1.5" lift rear Wheeler's Offroad progressive AAL packs, Airlift helper airbags, N-Fab nerf bars/side steps, all sittin' on Falken 265/75/16s on American Racing 16s
    So for a while now, my brake pedal would go to the floor, but gain back pressure after a few pumps. There was no fluid loss and there was no need to bleed the brakes.9 I've seen other threads about the issue. I was told it was the master cylinder, a siezed caliper, etc. I dealt with it for a while but after putting wheel spacers on realized that my wheel bearing was bad on the drivers side. It was really bad. I just replaced it and my brake issue is gone.
    Anybody ever have a similar issue?
  2. Jul 12, 2017 at 5:11 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    usually a wheel bearing has no effect on brakes, air in the system, bad master are the usual suspects.
    DrFunker and Clearwater Bill like this.
  3. Jul 12, 2017 at 5:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Coinsidence.
    Please fix your brake problem before you are in a situation you can't pump it fast enough and injure someone.
    Your description is classic internal seal failure of the master, bypassing fluid and dropping pressure.
    If you've never done a master before, get someone to help who has. Its not hard, but done wrong.....
    Then do a full fluid replacement / bleed of the whole system.
    Speedo, mjp2, DrFunker and 1 other person like this.
  4. Jul 12, 2017 at 5:39 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Best advice....please implement it OP. :D
    anthony250f likes this.
  5. Jul 12, 2017 at 5:50 AM
    LukeB
    LukeB Member
    Luke
    Boise, ID
    2010 Double Cab Long Bed
    I had this exact issue. The wobble/slop in the wheel would spread the caliper on the side with the bad wheel bearing while driving and it would take 1.5-2 pumps of the pedal to recompress the caliper again.
    That being said, my wheel bearing was near failure and had 1/4-1/2" of slop in the wheel so probably more than most people with a bad wheel bearing. I also replaced front pads, rotors, and rear shoes and re-bled just to be safe.
  6. Jul 12, 2017 at 6:31 AM
    Tacoman James
    James
    Maine
    This describes my situation exactly. And yes, my wheel bearing was probably that bad. The spacers really stressed it out.
  7. Jul 12, 2017 at 6:35 AM
    Tacoman James
    James
    Maine
    I know it doesn't seem related. I'm sure it is a coincidence, but it sure didn't seem like it. Could the brake squishiness have anything to do with the caliper? Perhaps taking the caliper off and putting it back together somehow helped.
    Or maybe the issue will come back.
  8. Jul 12, 2017 at 6:38 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It will come back
    Fix the real issue
  9. Jul 12, 2017 at 6:39 AM
    Tacoman James
    James
    Maine
    So are you saying the issue went away with a new bearing?
    LukeB[QUOTED] likes this.
  10. Jul 12, 2017 at 6:49 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Wrong, worn bearings will spread the caliper open since the rotor wont be inline
  11. Jul 12, 2017 at 6:52 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    This ^^^^^^^
  12. Jul 12, 2017 at 6:56 AM
    anthony250f
    Anthony
    San Diego, CA
    I had extreme worn wheel bearings....one had a complete failure and my brakes worked fine
  13. Jul 12, 2017 at 7:35 AM
    LukeB
    LukeB Member
    Luke
    Boise, ID
    Yes, no brake issue after wheel bearing was replaced. Obviously YMMV but the wheel bearing was the root cause of my brake issue.
  14. Jul 13, 2017 at 6:34 AM
    Tacoman James
    James
    Maine
    This appears to be my same situation. It really is completely better with the new bearing. Before, it was every time that I would press the pedal I would have to pump it 1-2 times. Now it is back to normal directly after replacing the bearing. There's some sort of correlation. Thanks for the input guys.
  15. Jul 13, 2017 at 6:45 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Same issue here, slop in the wheel can open the caliper and you have to pump it back up.
  16. Jul 13, 2017 at 7:01 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  17. Jul 13, 2017 at 7:05 AM
    Tacoman James
    James
    Maine
    Okay, I am new to this forum. What is the Sub'd slang? I assume its like a Bump (bring up my post)
  18. Jul 13, 2017 at 7:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    It means they've subscribed to the thread so they get notifications or can find it in their 'watched threads' section in the future.
    Of course it does nothing for anyone else except clutter up the thread with a useless post.
    All you have to do is click 'watch thread' at the top right of the page, and you will be subscribed.
    Pigpen and knottyrope like this.
