Brake-pedal-to-start delete?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HMA, Jan 13, 2023.
  1. Jan 13, 2023 at 9:39 AM
    HMA
    HMA [OP] Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    '22 TRD OR - I like to reach in and start my truck, get my shit together, get in and go. Is there any way to modify it so that you don't have to press the pedal?
    HondaGM likes this.
  2. Jan 13, 2023 at 9:43 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Use the remote start feature if you have it
    Rusty66 and HondaGM like this.
  3. Jan 13, 2023 at 9:46 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    These require you to start the truck back up once you get in because it turns off no?
    HondaGM, Just_A_Guy and CaptainBart45 like this.
  4. Jan 13, 2023 at 9:46 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    What happens when you currently tap the start button without your foot on the brake pedal?
    How would you integrate the current accessory mode functionality into a ‘start without needing brake pedal’ feature?
    This is a can of worms that is not worth the effort. But yes, I agree it’s annoying not being able to just stick the key in the tumbler and turn the vehicle on.
  5. Jan 13, 2023 at 9:48 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Reach down with your left hand, push on the brake, and use you right hand to start the truck.
    Vmax540, twitchhero, sbl23 and 23 others like this.
  6. Jan 13, 2023 at 9:54 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This is what I do since the remote start is stupid on these trucks.
  7. Jan 13, 2023 at 9:55 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Hit the Clutch Start Cancel Switch
  8. Jan 13, 2023 at 9:55 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You can just hold the button down for 10 second I think. But probably easier to just push the brake with your hand.
  9. Jan 13, 2023 at 9:57 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    This sounds like an order of operations issue.
    I like to get my shit together, get in, start, and go.
    More efficient. Fewer steps.
    steve1503, Chew, bbartol and 6 others like this.
  10. Jan 13, 2023 at 9:58 AM
    CaptainBart45
    Bart
    Work in progress...
    I never tried the ten second hold down, I would be a little nervous.
    HondaGM and Jeffch like this.
  11. Jan 13, 2023 at 9:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    -- One press gives you Accessory functions.
    -- Two presses gives you Ignition On functions, everything but the engine is not running.
    You can hit the brake pedal and the PTS button again to start the engine.​
    -- Holding it down should eventually start the engine without touching the brake pedal.
    -- Putting it in Neutral and hitting the PTS button will shut the engine off, but allow you to keep the Accessories on. I think they will shut off after 20min?
  12. Jan 13, 2023 at 9:59 AM
    CaptainBart45
    Bart
    Work in progress...
    When it gets over 120 out here I like to open the doors and run the AC for a couple of seconds before I get up in there.
  13. Jan 13, 2023 at 9:59 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I just tried it. Doesn't work, at least from the driver's seat. For thoroughness I did not try it while sitting in the passengers.
    HondaGM likes this.
  14. Jan 13, 2023 at 10:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Why? It's just at button that is at your command. Not a self destruct feature.
    Chew and HondaGM like this.
  15. Jan 13, 2023 at 10:02 AM
    CaptainBart45
    Bart
    Work in progress...
    I am thinking I could be reseting the flax capacitor.
    HondaGM likes this.
  16. Jan 13, 2023 at 10:02 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I'm a wild bastard, I still climb in and go. But I also run a pretty stout sunshade and crack the windows on a summer day. It keeps the cab down to low oven temperatures.
    Chew, HondaGM, tonered and 1 other person like this.
  17. Jan 13, 2023 at 10:03 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Whatever happened to the concept of getting your shit together, get it all into the truck, hop in, start it and go?
  18. Jan 13, 2023 at 10:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If only. Haha!
    HondaGM likes this.
  19. Jan 13, 2023 at 10:06 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My 18 will start without using the brake.
    Hit the start button once accessory comes on hit it again and hold it like 15 seconds truck starts.
    easier to use the brake pedal!
    Just more stealthy cause no brake lights.
    musicisevil, Zerksees and HondaGM like this.
  20. Jan 13, 2023 at 10:09 AM
    Just_A_Guy
    On the hunt
    A truck
    It was a rhetorical question. Point was there is functionality built into tapping the Start button without foot on brake.
    Ever have your vehicle sitting outside in 120 degree heat?
    HondaGM likes this.
