Brake-pedal-to-start delete?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HMA, Jan 13, 2023.
  1. Jan 13, 2023 at 10:18 AM
    Clearwater Bill
    Billy
    Largo Florida
  2. Jan 13, 2023 at 10:27 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    It does work... I've done it before on my 2017. But I think it's more like 13-15 seconds. It seems to take F O R E V E R. :burp:
    musicisevil and HondaGM like this.
  3. Jan 13, 2023 at 10:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I always thought it did. I just tried holding mine for 30, and nothing.
    DES2009[QUOTED] and HondaGM like this.
  4. Jan 13, 2023 at 10:35 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Dunno. When I did it I was standing outside the truck with driver's door open. My back and neck started getting stiff before the truck started.. but it did eventually start.
    Pushbutton start.
    musicisevil likes this.
  5. Jan 13, 2023 at 10:35 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    you can’t be in accessory mode you have to push it twice so all your warning lights are on.
  6. Jan 13, 2023 at 10:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Warranty. Tell 'em you heard it on the web it should work. Threaten a class action suit. Demand your rights.
    :D
    MadKatt and Rock Lobster[QUOTED] like this.
  7. Jan 13, 2023 at 10:36 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    It was. :notsure:
  8. Jan 13, 2023 at 10:44 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    so I’m wrong you have to hold the start button on second push!
    If pushed twice then hold it no work!
  9. Jan 13, 2023 at 10:56 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    "on these trucks"? Is there something better from other manufacturers?
  10. Jan 13, 2023 at 10:59 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I just tried it in my 19 and it worked. Pushed once and held down. Took about 15 seconds.
    It's easier to just hit the brake but it did work for me.
  11. Jan 13, 2023 at 12:25 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    yes.
    my last two Ram’s, and last 4 other various vehicles all stayed running after you used remote start.
    the Rams, and the GMC were PTS and the others had physical keys.
    remote start the vehicle, get in within 10-15 minutes, push start button or insert key and turn to “run”, put it in gear and drive.
    if you didn’t have they key fob inside the cab, it wouldn’t drive on the PTS models.
    mph, and better activation of the remote start.
    either push and hold a remote start button, or press lock once, then press and hold a remote start button. no silly and nearly impossible sequence to hit to start.
  12. Jan 13, 2023 at 12:31 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Had the 12 volt solutions 2 way remote start on my 12.
    It stayed running just needed a key and a touch of the brake pedal.
    Also had a pit stop mode.
    Was great with the dog!
    Push and hold on remote it would run and use ac or heat while he waited for me if I stopped at the store.
  13. Jan 13, 2023 at 12:32 PM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    you could wire in a small momentary switch next to the ignition that is tied into the brake circuit.
    press the brake button and then the start button. could also double to just turn the brake lights on if needed.
    Two possible issues with this:
    1. these trucks are fairly smart, and depending on your model, activating the brake switch without actually building pressure could cause some codes.
    2. Tying into some factory wiring spooks some people.
  14. Jan 13, 2023 at 12:33 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Why am I still here
  15. Jan 13, 2023 at 1:34 PM
    #35
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    You are intellectually intrigued?
  16. Jan 13, 2023 at 1:36 PM
    #36
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    Or I like the abuse
    CaptainBart45[QUOTED] likes this.
  17. Jan 13, 2023 at 2:29 PM
    #37
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Maybe not 120° air temps, but after a couple hours in 100° air temp under direct sun. Yeah, it's hot. But a short drive with the A/C blasting mitigates that pretty quick.
    MadKatt and Just_A_Guy[QUOTED] like this.
  18. Jan 13, 2023 at 2:40 PM
    #38
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    A trailer brake gives you a remote brake switch. Press the trailer brake, then press the PTS switch. It works with my Redarc brake controller.
  19. Jan 13, 2023 at 4:13 PM
    #39
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Yes. 2020 Nissan Armada. Remote Start, then unlock door, vehicle continues to run, then get in, then step on brake and press start button, then drive away. If you shift out of park before taking those step, the engine kills.
  20. Jan 13, 2023 at 5:13 PM
    #40
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    ^^^^^ THIS!
    Get a trailer brake controller, reach in hit the brake controller, and push the button. like my good friend Ross Perot used to say... Problem addressed, problem solved. Ski
