Brake pedal vibrates
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DKaska, Aug 24, 2017.
  1. Aug 24, 2017 at 6:28 AM
    DKaska
    DKaska [OP] Active Member
    So I have a 17 Off Road and not sure how many people noticed, but when you start the truck it pushes the brake pedal up some. Well does anyone know what does that and how important it is? My brake pedal has been acting up, it vibrates when you start up the truck instead of pushing the pedal up. Also vibrates during some hard brake pressure. I'm 1400 miles from home and it seems to be fine besides the vibration.
  2. Aug 24, 2017 at 6:34 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Mine has done the same for 15k miles now. Dealer said no issue. I think it happens too often, but time will tell. I have an extended warranty.
    It's the ABS pump I believe doing some sort of self test. If you leave your ignition turned on and listen under the hood for 10-15 minutes, it'll do it on it's own at least once or twice.
  3. Aug 24, 2017 at 6:58 AM
    jaseb
    jaseb Well-Known Member
    Who?
    Raleigh, NC
    2017 TRD OR DCSB 4WD
    stuff
    Mine also does the same thing both at start up and when I first hit the pedal any time I'm coming to a stop. Had it at the dealer last week for some ABS and vehicle stability warning lights (with only 2800 miles on it) and brought it up as something to check out and they "couldn't replicate" the vibration. Pretty easy to replicate it in my opinion as it happens all the time but with all of the recalls it probably never really got looked at.
  4. Aug 24, 2017 at 7:01 AM
    Bishop84
    Bishop84 Well-Known Member
    Normal, 4runners have been doing it for a decades, it's a characteristic of the ABS system the OR has.
    Definitely mention it to them during the next service so it's checked out and documented.
  5. Aug 24, 2017 at 7:08 AM
    jaseb
    Who?
    Raleigh, NC
    stuff
    Good to know, now I can focus on bothering my dealer about my howling diff :rofl:
  6. Aug 24, 2017 at 8:28 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Edited:
    I had vibrations in my brake pedal that were tied to a warped rear DRUM... just my experience but worth a look.
  7. Aug 24, 2017 at 8:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    How did you end up with a Rear Brake Rotor?
  8. Aug 24, 2017 at 9:02 AM
    bshammer0
    Brandon
    Nashville, TN
    edited ;)
    shakerhood[QUOTED] likes this.
  9. Aug 24, 2017 at 9:14 AM
    shakerhood
    Southern Ohio
    When I first read it i thought maybe you did some sort of Rear Disc Conversion.
  10. Aug 24, 2017 at 11:42 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    If it's vibrating like a cell phone that's normal for the Tacoma. I eventually stopped noticing it, but it never stopped happening.
  11. Aug 24, 2017 at 11:56 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There's nothing to check or document, it's perfectly normal. You're just feeling the electric brake booster pump up pressure in the system.
  12. Aug 24, 2017 at 12:28 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
