Brake pedal went a little soft...
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Nov 15, 2009.
  1. Nov 15, 2009 at 12:07 PM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I was driving back to my dorm today and I hit the brake pedal to stop at a light. When I did, the pedal went the normal distance with the right amount of resistance (that I am used to) but then it felt like some sort of barrier broke and it went quite a bit further suddenly.
    I tested it repeatedly on the way back, and it did the same thing every time, except there wasnt a threshold where it used to stop. It sort of went spongy, but not entirely.
    The brakes also seem to still stop fine, I just want to know what it could be and if I am going to randomly lose breaks at some point soon...
    thanks
  2. Nov 15, 2009 at 12:11 PM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    Check for moisture on the brake lines, you probably have a leak in the lines somewhere.
  3. Nov 15, 2009 at 12:32 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    could be the wheel cylinders mine was doing the spongy pedal . i pulled the rear tires to replace the shoes and noticed the driver side was leakin fluid and the rubber boots on the ends were thin and looked like swollen olives
  4. Nov 15, 2009 at 12:36 PM
    RattleTractor
    Harry
    VT
    Hmm interesting... I also have changed in the past year the calipers, rotors, pads in the front and the shoes, drums, and hardware in the back.
  5. Nov 15, 2009 at 12:42 PM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    Maybe your master cylinder is bad?
    That was the case with my S-10 when I had a similar symptom.
  6. Nov 15, 2009 at 12:43 PM
    bullshooter
    bullshooter Active Member
    central illinois
    08' Indigo TRD Sport 4x4
    access tonno
    mine does this too. usually when the engine rpm's change when the heater or ac is on while sitting at a light. when this happens the truck will crawl forward
  7. Nov 15, 2009 at 1:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Crawl underneath the truck and start looking for leaks/or oil residue near where the brakes/lines are.
    Something else to try - have a buddy sit in the truck (preferably running, in park or neutral, ebrake on). Have your buddy step on the brakes as hard as he can..... while you crawl underneath and look for any signs of leakage.
    A hairline crack won't be noticable until you put it under load.
    Biscuits likes this.
  8. Nov 15, 2009 at 4:39 PM
    RattleTractor
    Harry
    VT
    OK I will do that when I go home this weekend. Can I drive around a little in the meantime or is that a bad idea?
  9. Nov 15, 2009 at 9:35 PM
    RattleTractor
    Harry
    VT
    bump...anyone know if im gonna die if i drive this damn thing too much?
  10. Nov 15, 2009 at 11:00 PM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
    Mine has done this since I got it(5 or 6 months) There's some seals leaking on mine in the back, I never noticed until I swapped my wheels out. I haven't even looked into fixing it. It's done fine for me.
    What seals could this be and about how much would it cost to fix it? Sorry to hi-jack op, but I think you'll be fine.
  11. Nov 15, 2009 at 11:12 PM
    gozar
    Arizona
    The only place I would drive it would be to someone who can diagnose and fix the problem. The brakes might seem o.k. now, but what if you have to make a panic stop? You may feel like you're being extra careful, but what if some bonehead-talkin-on-a-cell-phone pulls out in front of you, you jam on the brakes and whatever was performing marginally gives up the ghost?
  12. Nov 16, 2009 at 3:22 AM
    Janster
    Jandy
    Lancaster, PA
    Exactly what gozar has said...
    I wouldn't feel safe myself. If you knew exactly what the problem was - then you might be able to drive it for short (slow mph trips) depending on what the problem was. But, since you don't know what the problem is, I woudln't push my luck.
  13. Nov 16, 2009 at 6:06 AM
    RattleTractor
    Harry
    VT
    alright thanks. I'll drive it to my mechanic when I get a chance, I wish I could fix it myself, but I'm just to damn busy right now as a student.
  14. Nov 21, 2009 at 9:31 AM
    RattleTractor
    Harry
    VT
    OK, so heres an update:
    I still have that brake pedal problem, but I figured out that if I press it all the way past where it went originally (theres kind of a weak threshold there, but then it travels another 50-60% further) and release all the way up, when I press it down immediately after it only goes to where it should go.
    I don't know if that makes sense in writing, but thats what I have discovered and I want to see if it helps with the diagnosis
  15. Nov 21, 2009 at 1:12 PM
    Janster
    Jandy
    Lancaster, PA
    You can't make a diagnosis just from pedal travel....too many variables.
    Did you check the condition of your brakes (shoes, pads, rotors, etc)?
    Did you check for any leaks? Check your fluid level?
    How's your ebrake engage? How many clicks does it go when you pull the handle?
  16. Nov 21, 2009 at 1:16 PM
    gozar
    Arizona
    I would put my money on the master cylinder being bad.
  17. Nov 21, 2009 at 1:41 PM
    RattleTractor
    Harry
    VT
    I replaced all brakes (rotors, pads, calipers 1 year ago, shoes, hardware, drums 8 months ago). I have checked the fluid level in the past week several times and it has not gone down at all.
    Ill check for leaks again, but haven't found any yet.
    My ebrake is already shot...pulls out like 25 clicks (norm is 12-18), one of the levers on the back is frozen, and it doesn't hold the truck. But that is nothing new...that's been the case since I bought the truck.
    Master cylinder then?
  18. Nov 21, 2009 at 3:35 PM
    Janster
    Jandy
    Lancaster, PA
    When you replace the rear shoes - did you inspect the shoe wear? How were they wearing?
    Did you inspect, clean, and/or replace the star wheel adjuster? How about all the rear springs, etc (there are rear drum rebuild kits available)
    I would get the ebrake fixed first.....
    Did you replace the rear cylinders?
    Before jumping to conclusions on the master cylinder, I'd bleed the brakes entirely - this might flush out any particles in the fluid and/or if you find air in the system, then you know you have a hairline leak somewhere.
  19. Nov 21, 2009 at 3:42 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Yoy either have a leak, or a bad master cyl. When your pushing the pedal a couple of times your "pumping it up". Either way check for a leak now, when it finally lets go it isn't gonna be any fun, and most likely lead to a accident.
  20. Nov 21, 2009 at 8:25 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    sounds like a master cylinder to me. if you have any tools and about an hour or so its pretty easy to fix. remember where the lines went and bleed your brakes afterward.
