Brake pressure lost or not enough
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco0914, Aug 8, 2019.
  1. Aug 8, 2019 at 9:21 PM
    Taco0914
    Taco0914 [OP] Active Member
    Juan
    2014 black tacoma TRD SPORT
    None
    I have a 2009 tacoma single cab 4 cylinder base model. My taco loses brake pressure when I brake or when im braking the truck has not enough braking power I get a sinking pedal, I have changed my master cylinder from dealer part and my calipers are new and new rotors and pads. Any ideas what it can be!! Can anyone help out thanks
  2. Aug 8, 2019 at 9:25 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Mmm have you checked all your vaccuum lines to see if you have a vaccuum leak?
  3. Aug 8, 2019 at 11:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Air in the system. How did you bleed the ABS System?
    Make sure the rear shoes are properly adjusted. The procedure is posted in here somewhere.
    I'd bet air in the system.
    dbole007 and G59 like this.
  4. Aug 8, 2019 at 11:35 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Also make sure you dont have leaks anywhere
  5. Aug 9, 2019 at 5:23 AM
    Taco0914
    Juan
    None
    Have done all that dealer has bleed the system with the scanner and manually and still the same
    PzTank likes this.
  6. Aug 9, 2019 at 5:26 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    Your rubber brake hoses may need replacing because they are expanding when pressure is applied. Just a thought.
    Taco0914[OP] likes this.
  7. Aug 9, 2019 at 5:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    If a dealer has been doing the work, they need to fix their work.
    Keep in mind a bad master out of the box is not impossible. Additionally sometimes dealers sell reman parts to have a lower price option.
    I had a devil of a time bleeding an '04 Highlander, and Techstream was really needed to clear the ABS. You say they have done that, but it doesn't mean it was done correctly.
  8. Aug 9, 2019 at 5:34 AM
    Taco0914
    Juan
    None
    Well see I had 2 different dealers and and 3 different mechanic shops look at it and they cant find it
  9. Aug 9, 2019 at 5:34 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    ^^^^THIS^^^^
  10. Aug 9, 2019 at 6:34 AM
    Taco0914
    Juan
    None
    The dealer has not done anything my truck, all they have done was check it and say it was ok
  11. Aug 9, 2019 at 9:59 AM
    PzTank
    Above the Notches
    Is it ok? If they said it and it wasn’t then that should be on them
    You might need to have the ABS bleed through Techscan or whatever it’s called.
  12. Aug 9, 2019 at 10:20 AM
    Taco0914
    Juan
    None
    Ill be honest I had my abs bleed already with the scanner 4 times and its the same thing
    PzTank likes this.
  13. Aug 9, 2019 at 10:20 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Are you new to the truck? My pedal in my 2009 Regular cab 4cyl has always felt softer than most trucks/cars that I've driven. Are you not able "lock" up the brakes if you needed to? Or do they just feel like there is a lot of pedal travel?
    Taco0914[OP] and SR-71A like this.
  14. Aug 9, 2019 at 10:21 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    brake booster
    Skyway, tcjacado and Taco0914[OP] like this.
  15. Aug 9, 2019 at 10:23 AM
    Taco0914
    Juan
    None
    Correct my brake wont lock up when i brake hard
  16. Aug 9, 2019 at 10:24 AM
    Taco0914
    Juan
    None
    The booster never changed it out but it has pressure when i release the hose
  17. Aug 9, 2019 at 10:24 AM
    wilcam47
    Will
    Bourbon state
    sounds like your brake booster is bad/going out.
  18. Aug 9, 2019 at 10:45 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP do you have a manual? check for leaks on the clutch master cylinder / slave cylinder as they use brake fluid as well from the brake master cylinder reservoir
  19. Aug 9, 2019 at 11:12 AM
    Taco0914
    Juan
    None
    No mine is automatic
  20. Aug 9, 2019 at 11:23 AM
    nd4spdbh
    SoCal
    Hmm, pull the vacuum booster vacuum hose and see if its oily. Maybe you are leaking fluid into there.
