Brake problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Okie longwinger, Nov 8, 2020.
  1. Nov 8, 2020 at 4:04 AM
    Okie longwinger
    Okie longwinger [OP] Member
    2011 Tacoma
    2011 extra cab 4x4 v6 auto 210,000
    six months back seems like I lost some brake pedal, but still stopped ok, except I noticed on gravel or dirt, it would slide front wheels.
    Replaced front pads, they were paper thin but not into the metal.
    Rear shoes looked almost perfect, at 196,000 mi.
    brake pedal seems to be worse now, fluid has never been low.
    Left rear wheel bearing got noisy, replaced it, hook up brake line and bleed with a one man bleeder. has about two ounce bottle, then bleed right side, no bubbles. Both sides only put about 1/4 bottle of fluid in it after each bleed. And I pumped it multiple times with very little if any pedal. Bleed right front brake, then left front and both of them after three pumps would almost fill the bottle. And there was about a quarter of what I would expect of brake pedal. Brake fluid never got low, checking it after each bleed. I now have very low pedal and front brakes seem to be the only ones working. I am thinking master cylinder, but thought I would check in here first.
    Any help is appreciated
    thanks
    Oscar
  2. Nov 8, 2020 at 4:11 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The rear shoes probably need to be adjusted.
    SR-71A and RedWings44 like this.
  3. Nov 8, 2020 at 4:32 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Agreed. The shoes don't move all that much and the majority of your stopping power is up front anyway, so if the shoes aren't properly adjusted, it can seem like you have little to no brakes.
    Also, have you followed the brake lines just to make sure there were no wet spots? I know you said the fluid was never low, but still.
  4. Nov 8, 2020 at 4:59 AM
    Okie longwinger
    2011 Tacoma
    yes, the rear brakes did need a lot of adjustment, but did not change anything
  5. Nov 8, 2020 at 5:02 AM
    Okie longwinger
    2011 Tacoma
    I have not followed the brake lines, but I will check, I mentally eliminated that since I was never low on fluid, but who knows?
  6. Nov 8, 2020 at 5:06 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Did you adjust them so the brakes lock up then back off a couple clicks?
    You could have a bad master cylinder but I suspect something with the rear drums.
  7. Nov 8, 2020 at 6:00 AM
    Okie longwinger
    2011 Tacoma
    No I didn’t adjust them up that tight
    Guess I will give that a try this afternoon
    Thanks
  8. Nov 8, 2020 at 6:14 AM
    RedWings44
    Michigan
    Yeah, drum brakes can be kind of weird. What you think is adjusted enough isn't enough resistance.
  9. Nov 11, 2020 at 9:39 AM
    Okie longwinger
    2011 Tacoma
    Update on the brake issue
    Adjusted rear brakes to the point of significant amount of drag, couldn’t tell if it changed any
    Bleed all brakes again and got more air out of left rear, well that seems to have done the job, brakes working normally now
    Thanks for all the suggestions!
    RedWings44 and Torspd like this.
  10. Nov 11, 2020 at 10:02 AM
    Muddinfun
    Muddinfun Well-Known Member
    I hope you didn’t leave it with a significant amount of drag.
  11. Nov 11, 2020 at 10:05 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    You should have them right enough that when you spin the hub, it shouldn't spin freely more than 180*.
  12. Nov 11, 2020 at 10:13 AM
    MR5X5
    MR5X5 Well-Known Member
    Take a look at that left rear brake line - that it had air on the second check is curious since you certainly sound like you know how to bleed brakes- could indicate a leak in that branch.
  13. Nov 11, 2020 at 11:18 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You don't think they will self clearance pretty quickly?
    RedWings44 likes this.
