Brake problems when offroad, insight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishingInSand, Jan 30, 2017.
  1. Jan 30, 2017 at 2:35 PM
    FishingInSand
    FishingInSand [OP] Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Hey all, so during the last meetup at superstition, I noticed slowly my brakes started to get worse and worse as the weekend went on, and let me try to explain what I felt/ dealt with as I haven't had this issue before (still trying to learn as I go).
    So when offroad speaking, I would press the brake pedal there would be a kind if grinding and almost like a force pushing back on the pedal so I couldnt push it in. I would only be able to actually slow down or stop by pumping the brakes very fast and short bursts. It was actually quite confusing and somewhat terrifying.
    Not sure if it was abs or what not, as like I said I'm slowly (but surely) learning how my truck operates and how to fix problems.
    Thanks in advance to anyone who might help me alleviate the problem.
  2. Jan 30, 2017 at 3:24 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    ABS traction control.
    Those of us who drive in winter are VERY familiar with this safety feature.
    Do NOT pump your brakes if your vehicle is equipped with ABS. The ABS system is already doing it for you. By pumping you are defeating the system.
  3. Jan 30, 2017 at 4:49 PM
    Pigpen
    Dan
    Northwest Montana
    Definitely ABS. If you are having this experience, you need to look into the ABS kill switch mod. The ABS on these trucks will try to kill you in steep slippery conditions.
    Stig, EDDO and FishingInSand[OP] like this.
  4. Jan 30, 2017 at 4:53 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    For steep slippery I recommend 4LO in 1st gear. Granted I'm over geared but I don't need brakes very often....
    FishingInSand[OP] likes this.
  5. Jan 30, 2017 at 4:55 PM
    Pigpen
    Dan
    Northwest Montana
    But you want them to work when you need them :D
  6. Jan 30, 2017 at 5:16 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    lookup abs killswitch, could save your ass offroad 1 day
  7. Jan 30, 2017 at 5:42 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I would have your brakes checked. If you can't do it take it to someone who can. Make sure you don't have a mechanical problem first. Rusted or pitted brake rotors will cause abs activation on dry road. Once you are sure your brakes are ok and that is was most likely the abs then install an abs shut off switch. You have to be careful with the abs shut off because you will skid. Take things slow at first until you are used to non abs brakes and have fun.
  8. Jan 30, 2017 at 5:45 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Good ole Toyota Anti Braking System :bikewhoops:
  9. Jan 30, 2017 at 6:33 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Thanks guys I was worried I broke something bad but didn't know, and like I said it doesn't happen on the street only offroad in very slippery conditions ie: mud and sand
    Will definitely look into getting that done especially since my truck is on Jack's waiting for my shock to get fixed by down south motorsports... who are pretty awesome by the way
  10. Jan 30, 2017 at 6:38 PM
    Justinlhc
    You should see it on ice :eek::bananadead:
  11. Jan 30, 2017 at 6:41 PM
    Hugh Morron
    Bill
    Ha Ha Ha Toyota Anti-stop Brake System.
    inwood customs likes this.
  12. Jan 30, 2017 at 6:45 PM
    badger
    badger Well-Known Member
    07 SR5
    I killed my abs permanently, just cut a wire and done. No plans to ever turn it on. The only problem is that I could never find a way to kill it without activating the dash light.
  13. Jan 30, 2017 at 6:50 PM
    inwood customs
    Dave
    The abs goes batshit crazy on pavement sometimes.... just the slightest hint of a squirrel fart near the road and the truck wants to take 1000ft to stop, buzzing and vibrating like an adult toy on tile.
    As for downsouth motorsports, they are def a standup crew.
  14. Jan 30, 2017 at 6:53 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I saw about the abs kill switch and it looks simple as the anytime fog light mod I did. Does it work on prerunner's too? they were talking about doing it on 4x4.
  15. Jan 30, 2017 at 6:53 PM
    inwood customs
    Dave
    Worked on my 2wd offroad.
  16. Jan 30, 2017 at 6:54 PM
    Pigpen
    Dan
    Northwest Montana
    You don't have TRAC or VSC
  17. Jan 30, 2017 at 6:54 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Okay, mine is a sport ( auto lsd) not an offroad so I didn't know if that made a difference. Thanks man
  18. Jan 30, 2017 at 6:56 PM
    inwood customs
    Dave
    Its been quite a while, but i think there were 2 writeups... i wanna say 1 was for the offroad, and the other was not.
    I used the writeup by......."Crom" i think
  19. Jan 30, 2017 at 7:00 PM
    Justinlhc
    Worked on my Sport PeeRunner. I can't remember which writeup I followed, but I believe it required a double pole, double throw switch.
  20. Jan 30, 2017 at 7:01 PM
    Pigpen
    Dan
    Northwest Montana
    The one for OR models tricks the computer into thinking the diff lock is engaged to disable ABS. The other is a simple on/ off switch.
